need some help
Old Apr 27, 2005
03civda's Avatar
03civda is an unknown quantity at this point
need some help
hello everyone. I saw that this had been talked about in some other threads, but I never got an answer. I installed GC on my 03 sedan, and when I turn now, I get a popping sound. I called GC and they said that I put the strut bearing on incorrectly, and they were right, I did. BUT, I fixed it and I am still getting the popping. I think the problem is with that little aluminum hat that sits on top of the spring. I think I have it upside down, but I'm not sure. Does anyone have pics of their front GC's so I can see if mine are upside down? Thank you!
Old Apr 27, 2005
scatman's Avatar
Still in the game...
have you installed them recently?? if so , the popping noise is normal, especially when turning....the spring just needs time to sit right. it happens to me too everytime i do a spring job.....greasing it good would also help
Old Apr 27, 2005
03civda's Avatar
yes, I just installed them Sunday. But I'm still kind of worried.
Where do you grease it, and what product exaclty do you use?
Old Apr 27, 2005
scatman's Avatar
vaseline would work fine, i used that a couple times and greased both parts of the spring (top/bottom) and especially where it sits....but i wouldnt worry, give it at least a couple weeks
Old Apr 27, 2005
03civda's Avatar
really, it just sounds terrible. Thats all it will take is just vaseline? Do I need to put it on the actual spring itself? Also, did it take your springs a couple weeks to stop making that sound?
Old Apr 27, 2005
scatman's Avatar
read my post again, i explained where to grease it....and use a lot. the sound i got was a binding, clank-like noise when turning and yes, it takes a few weeks.
Old Apr 27, 2005
03civda's Avatar
Sounds good. What exactly causes that noise to begin with?
Old Apr 27, 2005
scatman's Avatar
the springs are brand new and have never really been squished down with the load of the car weight....so it just takes them a little time to settle and then they're good to go.
Old Apr 27, 2005
03civda's Avatar
Thanks Scatman, I appreciate it. That puts my mind at ease a little more. I will try it out in the morning and we'll see how it works out.
Old Apr 27, 2005
scatman's Avatar
reps?
ur welcome.
Old Apr 27, 2005
03civda's Avatar
on the way!
Old Apr 27, 2005
03civda's Avatar
One more question, is it bad for the car to let that keep going on?
