TEIN SS-P: great feel! easy to align, and tires rubbing [Problem Fixed]
Old Apr 9, 2005
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
Alrighty, i had no digicam for the time being, so I couldn't take pics of the TEIN SS-P install, but it dun matter, is just a SS system with gold upper mounts.
on to the issue:
Right front tire rubs when turning steering wheel ALL THE WAY to the left. Its leaving scrape marks on the inner wheel well.
I have a 2 finger gap (at least) drop in the front, so its NOT slammed, not even close.
Got my alignment done, and its 0 deg camber on the left, and -1/8 degree on the right. I have a -1.5 degree camber on the rear...if that matters
anyone know what i can do? if i raise the fronts again, i'll throw off the alignment. The guys at the alignment shop said if they pull the front out the camber will be positive and that's not gonna be good. So now i dunno what to do. Please help!
Old Apr 9, 2005
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
maybe you should tell us what kind of rims and offset you have, i think that'll help.
if you're on stock, thats weird. cuz i got barely one finger gap all around on tein basic. i ain't rubbing.
Old Apr 9, 2005
§C§H§O§C§O§B§O
16x7" with 205/55/16 yokohama
Old Apr 9, 2005
K20me's Avatar
There's your problem, 205/55/16 tires. I had the same size tires on my car, and I even RAISED the rear suspension up to a 3 finger gap but still got rubbing. Smaller tires (205/50/16 is ideal, but 205/45/16 will also do) will stop the rubbing. Good luck.
Old Apr 9, 2005
wonderz's Avatar
wonderz is on a distinguished road
55 is too tall for 16"?
Old Apr 9, 2005
§C§H§O§C§O§B§O
thanks for that input...but i had 205/55/16 on my hayame's and i had no rubbing issue whatsoever, and i was dropped lower on the hayames. Plus, the rear of my car doesn't rub, its the fronts, and only if the steering wheels is turned all the way to the left.
205/55/16 is perfect for me, and according to the tire calculator and the folks down at discount tire co, is the correct size for a 16" rim (actually, 215/50/16 is the correct size, but that's a rare size, and not many brands make it). 205/45 will drastically change the speedometer reading (5% too fast), ur mileage will be seriously off after long periods of time (5 mile error every 100 miles you travel)
plus, there's no way i'm gonna get new tires just for this...lol...too much $$$$$$ >_<
Old Apr 9, 2005
robbclark1's Avatar
Retired suspension supermod.
Run -1 degree camber front and -.8 rear. See if that helps. Where are they scraping (top or front)?
Old Apr 9, 2005
§C§H§O§C§O§B§O
erm, i dunno how to describe it, the best way i know how is to use the unit circle:
its scrapping at the point pi/4 so like 45 degrees between top point and front point.
Old Apr 9, 2005
runner1738's Avatar
will these work with edfc on a 2005 lx sedan
Old Apr 9, 2005
robbclark1's Avatar
try more negative camber. You are saying it is is about at 10 o'clock or 10:30 on the circle right?
Old Apr 9, 2005
§C§H§O§C§O§B§O
more like 1:30
Old Apr 9, 2005
§C§H§O§C§O§B§O
yes, u can slap this on a LX and fit the EDFC as well ^_^ thanks to tein's new design, they made the SS/SS-P/FLEX all compatible with the EDFC without having to cut your hood and what not...
riley has it on his sedan (though he has the FLEX system)
Old Apr 9, 2005
runner1738's Avatar
awesome , but the only difference betwen the ss- p and ss are the upper plates? not the spring rates or something, cause i need something soft for our family sedan
Old Apr 10, 2005
§C§H§O§C§O§B§O
yesh...and on the SS-P the springs are tappered (linear) and they aren't on the regular SS's
Old Apr 10, 2005
runner1738's Avatar
what does having them tappered do?
Old Apr 10, 2005
§C§H§O§C§O§B§O
better performance, but less comfort...at least that's what i was told by tein
Old Apr 10, 2005
robbclark1's Avatar
So it is the back of the tire/fender well? Still try a degree or 2 of camber. If you go 2 degress rotate your tires more often. When you get new tires, get shorter ones, 45s or 50s.
Old Apr 10, 2005
§C§H§O§C§O§B§O
alrighty...thanks rob, i'll take it back to the shop on monday and see what they can do for me... alignment shops in SD really suck...none of em have experience with lowered vehicles.
bsmiley
Apr 27, 2015 01:27 PM
bo_red
Apr 23, 2015 10:09 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
technosilver
Nov 14, 2001 10:58 AM
