Pillows What do they do?
Old Mar 19, 2005
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
Ok soo, I returned my K Speeds. Decided to go with a brand name instead. Now I decided that Tein SS are my goal! But now...I was reseraching on their site and they have 2 models for our civics. One with pillowballs and one without. Which one do I need? I can have either right? Cuz I can use stock pillowballs or get the tein ones. Now my question. What do they do? and why if I decide to get the tein pillow ***** is the difference between stock and tein? Does teins have some type of magic in them?
I ask this question because I know a friend who owns a company and he will give me the Tein ss with pillowball for only $1200.
Old Mar 19, 2005
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Pillow blocks replace the top upper mount on the front strut. They allow for adjustments of camber on the front wheels.
If you can afford them, they will be a good investment. You should get improved feel on the top mount and you will not need a camber kit for the front wheels.
Old Mar 20, 2005
robbclark1's Avatar
Retired suspension supermod.
Pillowballs are metal upper mounts that do not allow the shock to wiggle around a bit. Usually there is a rubber upper mount that allows some movement. Not all pillowball upper mounts allow camber adjustment. You can have just a regular plate with pillowball upper mounts. They are noisy and rough.
Old Mar 20, 2005
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
for a street car you don't need them, but for a track car it would be recomended. on the street they will be rough and loud just like rob said. plus you have to lube them every once in a while.
Old Mar 23, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
they are loud....
rob i gotta lube mine occasionally.?
mine sound bad.. i need to retorque my rear nuts tho.. and put some lock-tite on em.. the stiffness causes vibrations that loosen the nuts..yeah dont ask
riley
Old Mar 23, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
If the pillowball itself is loud, you got problems. I don't think you gotta lube it either, but I usually do.
What you hear is the spring and the metal perch and all the other metal when you hit a bump. Its not the pillowball.
Old Mar 23, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
what i hear is the nouse traveling from metal/metal.. like a solid surface.. oem had a rubber bushing.. that caused a sound barrier
riley
TeLLy
175
Mar 23, 2008 02:15 AM
kickercivic1
Dec 22, 2005 09:57 AM
