Need help installing coilovers!!!!
Old Mar 18, 2005
Mr.honda's Avatar
Mr.honda is an unknown quantity at this point
I just got my adjustable coilovers not the whole thing but the kind with just the spring and the threaded collar. With the spings so much smaller and all the little set screws I don't know how to put everything together. Can anyone help me?
Thanks josh.
Old Mar 18, 2005
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
those are sleeved coilovers. may i ask what brand are they?
the 2 shorter smaller springs go up front while the taller 2 springs go in the rear.
you probably received 2 top metal mount plates, those 2 top metal plates (that are circular shaped and gapped in the middle) go on TOP of the front coilovers/springs.
then each spring has a coilover thread/perch.
goodluck
Old Mar 18, 2005
Mr.honda's Avatar
on the front if I just slide the pice that the spring sits on down it sits on the top of the shock and there is a big gap between there and the actual bottom part where the factory spring would sit and at the top where the threaded part is what keeps it from moving over because the only thing up there is the top part where the strut bolts to the wheel well it just don't look right
GolNat
Jan 12, 2021 09:06 PM
Misfit2613
Jul 30, 2015 09:49 AM
JKWood
Jul 28, 2015 03:45 PM
mHo2
Jul 27, 2015 12:57 PM
EM_WON
Jul 22, 2015 06:49 PM
