civic 05 suspension.....
Old Mar 6, 2005
jesusmzazueta's Avatar
jesusmzazueta is an unknown quantity at this point
Talking civic 05 suspension.....
yes i have read the faq on suspensions but it didnt fully answer my question so i decided to post it here to see if anyone can answer it.....im planning on lowering my car (05 civic coupe) but im not planning on replacing the stock wheels or tires just yet.....my question is that if i do lower the car now with either neuspeed race or sport springs with the rear camber kit, will i have to replace the camber kit once i get my new 17 or 18 inch wheels and tires installed or do i just have to adjust the camber????
thanks
Old Mar 7, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
i dont think you'd have to replace or adjust the camber with a different set of wheels. 05 suspension should be the same as 03 at the very least.
Old Mar 7, 2005
scatman's Avatar
Still in the game...
you wouldnt have to replace the camber kit, just adjust it. i wouldnt even bother getting one though, its really not that bad at all.
Old Mar 7, 2005
MishBallzEM2's Avatar
I'm The Ballz Of 7th Gen
MishBallzEM2 is an unknown quantity at this point
camber kits arent worth the money unless ur like really really slammed...even with the race springs u wont be so low that it will be necessary to have the kit
Old Mar 7, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
You're kidding right? You seen camber after a 2+" drop?
Old Mar 7, 2005
robbclark1's Avatar
Retired suspension supermod.
No, changing the tires/rims won't change the camber, caster or toe. Just swap wheels. We do it all the time for racing.
Old Mar 7, 2005
haha yeah i have ive had a car before with a 2.5 and my car now is a 2 and i have absolutly no camber problems
Old Mar 7, 2005
robbclark1's Avatar
What is "a car?" every car is different. Older civics would have active camber gain in the front when the car was lowered and very little change in the rear. the 7th gen is the opposite. So, again, each car reacts differently based on chassis and suspension setup. The 7thgen civic's rear tires will have a lot of negative camber lowering more than 1.5".
Old Mar 7, 2005
oh my bad...i had a 2000 coupe with race springs and i had coilovers on it...2.5-3 inches dropped and i had no camber issues at all...on my 04 coupe i have a 2" drop with stock wheels and tires and i have no camber problems at all...im not arguing with you guys im just stating what i have experienced first hand!!!
Old Mar 7, 2005
flyers27's Avatar
Broad Street Bullies
flyers27 is an unknown quantity at this point
my friend just installed neuspeed sports on his 03 civic with stock shocks and no camber kit and the camber is visible from the rear of the car on level ground. he's only using sports......i dont know why the camber looks bad.
Old Mar 7, 2005
bgoetz's Avatar
bgoetz is an unknown quantity at this point
I would like to see the print out on that because I would bet that you have - camber in the back. A 7thgen with a 2" drop will have negative camber in the back that is not going to vary from 7thgen to 7thgen. Now if it is a problem, that is another issue I personally would want negative camber in the back IMO
Old Mar 8, 2005
Xenin's Avatar
yeah so my camber is visible too, but my suspension is stock.
locozoko
Apr 6, 2002 09:00 PM
Cilvic
Nov 15, 2001 04:54 PM
bambuski
Nov 12, 2001 10:35 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
