coilover question
Old Mar 6, 2005
low04's Avatar
low04 is an unknown quantity at this point
coilover question
just installed the kw v2 coilovers. the dampening is all jacked up and rides horrible, worse than blown struts.
any suggestions on the easiest/best way to get it adjusted out?
i know how to adjust them but just curious if there was an easy way to adjust the dampening with out trial and error. i already messed with it for about 2 hours and am not getting very far. any ideas would be great
Old Mar 6, 2005
robbclark1's Avatar
Retired suspension supermod.
Are you sure the preloads are all set similarly? That means the front springs should be around the same height and the rear springs should be the same height. The dampening shouldn't affect your ride that terribly. Just put them all to full soft and see what happens. If you say that it is worse than with blown struts, I think you installed them incorrectly or did not set the spring correctly. You also have to realize that the springs are A LOT stiffer than stock.
Old Mar 6, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Figure out which way to turn the **** that makes it full soft. Thats about as good as its going to get. Unpreload the springs so that they just snugly fit between the collars at full extension so you don't have any extra effective rate worked into the system.
500 lb springs don't lend nicely to comfy rides.
Old Mar 6, 2005
low04's Avatar
well figured out the problem...i got a defective set. one of the rears is completely froze up so now after about 15 hours of messing with it, it comes down to this
Old Mar 6, 2005
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
^^thats gotta suck *****
GolNat
Jan 12, 2021 09:06 PM
SoslowEj666
Mar 8, 2016 01:10 AM
JKWood
Jul 28, 2015 03:45 PM
mHo2
Jul 27, 2015 12:57 PM
EM_WON
Jul 22, 2015 06:49 PM
