Camber Question
Old Feb 24, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
Camber Question
I would like to get a little more camber out of the front of my car. Already installed one pair on camber bolts, if I install another, will it give any more adjustment??
Old Feb 24, 2005
Zzyzx's Avatar
Autocross Junky
Yup. just make sure you install them right... The bolts on the top of the knuckle will push the top of the tire in... the ones on the bottom need to be set to push the bottom of the tire out.
Old Feb 24, 2005
Broken Road......
^^ Thanks!! I knew you'd be quick with the answer!
Old Feb 25, 2005
peteriap's Avatar
peteriap will become famous soon enoughpeteriap will become famous soon enough
How much more camber are you looking for? You need to be careful as it is not recommended by SPC to install two sets as you are reducing the strut bolt diameters a bit too much. PM me if you have any questions.
GolNat
Jan 12, 2021 09:06 PM
naokigoffi
Aug 30, 2015 06:19 PM
martinsmartin
Aug 15, 2015 07:34 PM
