Kind of bushing in SPC rear camber kit?
Old Feb 14, 2005
tavdawg's Avatar
tavdawg is an unknown quantity at this point
Is it just the rubber one or a polyurethane bushing?
Old Feb 14, 2005
peteriap's Avatar
peteriap will become famous soon enoughpeteriap will become famous soon enough
The SPC kit is only available with rubber bushings. If you are looking for a poly bushing kit, go with the Ingalls rear kit.
Old Feb 14, 2005
tavdawg's Avatar
Thanks man. I'm trying to upgrade all my bushings so I think I will spend the extra cash and go with ingalls kit.
Old Feb 14, 2005
gh0st's Avatar
TAQUITOS!!!!
i thought spc could come in poly or rubber
Old Feb 15, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Ingalls is ****. I wouldn't buy it. The abs brackets suck, the adjusters rust and sieze. Its just not worth it for a poly bushing.
Old Feb 15, 2005
nindoo's Avatar
Why is my vagina bleeding?
ahhhh crap I bought Ingalls. Are they made of lower grade materials than the stock camber kits?
Old Feb 15, 2005
Jap-Euro Fusion
There's no such thing as a stock camber kit. The stock UCA is just a stick.
The problem is they're just plain old steel, with an oil coating that comes off the first time you screw the adjuster sleeve on. So the first thing they do is rust. Theres not a whole lot you can do about it, they just made them as cheaply as they could apparently. Maybe adjust them to were you want them, then paint them over with rustoleum to keep them from rusting, then keep painting them every time you change the alignment, I dunno. I'm just gonna go buy some aluminum ones and call it a day.
Old Feb 15, 2005
peteriap's Avatar
We have sold a ton of these and this is the first I have heard of this rust issue. You must be up north. I will contact Ingalls on this. Thanks for the info.
Old Feb 15, 2005
Jap-Euro Fusion
I'll send you a picture next chance I get.
ernhole1
Dec 6, 2001 12:05 PM
speed werx
Nov 27, 2001 08:52 AM
andylao
Nov 9, 2001 07:36 PM
JeffSpeed21
Bolt-on Engine Performance
Nov 4, 2001 12:33 PM
ImmortalEX
Oct 31, 2001 10:00 PM
