Lowering coilovers...
Old Feb 11, 2005
xDCx's Avatar
xDCx will become famous soon enoughxDCx will become famous soon enough
Where or how can i go abouts getting that plate on the front suspension cut, so that i can reach the coilovers and adjust myself. No what im talkin about? and how much will it cost?
Also, I just have dropzone coilovers installed on stock struts @ one to no finger-gap for now. Opinions on how long my struts will last, should I bring my car up a bit? any input appreciated thanks.
Old Feb 11, 2005
dirtySAMURAI's Avatar
I log in from time to time
you could get it cut at any shop that does body repair? or your local speed shop.
your stock suspension will last you at the most 4 months and at the least 1 day.
Old Feb 11, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
You want to cut the lower spring perch off? DIY it, get a sawzall and go at it, then grind the edge off afterwards so you don't slice your arm up adjusting it. I would take the struts out of the car to do it though... wouldn't want to slip and hit the brake line.
Old Feb 11, 2005
xDCx's Avatar
ight hopefully they last me till May/June. i live in florida and there are hardly any bumpy roads, let alone any hills, so that'll help my struts to last.
Ya i need to cut the lower spring perch on the fronts. i suppose i could do it myself. thanks for the input.
Old Feb 11, 2005
VNlilMAN's Avatar
The Standard One
i hear its not easy... you can adjust it quite a bit without having to cut it so I would try to stay away from cutting it if you can.
wait nevermind.. on dropzone you use spanner wrenches to lock them huh. I know with ground controls I was able to get in and adjust it since the allen key fits just about anywhere
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
bhollie
Sep 22, 2015 11:08 PM
