How much can you feel a rear strut bar?
Old Jan 28, 2005
ajhdragon's Avatar
7thgens official a$$hole
just wondering what kind of diffrence i could look for if i get one. does it just make the car more rigid?
Old Jan 28, 2005
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
Not much.
Old Jan 28, 2005
Zzyzx's Avatar
Autocross Junky
You wont, as there isnt a whole lot of Lateral flex coming from the shock mounts on the rear. Thanks to the rear end being a Double wishbone style suspension, so Most of the lateral forces are transfered through the control arms to the chassis, rather then through the shock mount. Now if you could some how tie the upper control arm mounts together.......
Old Jan 28, 2005
2K1Civic17"Gabe's Avatar
I thought I felt a little difference. The rear end seems to sway a little more, but in a positive way. The rear end flips and skids a little more around turns now.
Old Jan 28, 2005
civic01vtec's Avatar
most likely it is all in your head
Old Jan 28, 2005
djmota's Avatar
not one bit. looks cool in the trunk tho.
Old Jan 28, 2005
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
If you upgrade the sway bar you will feel that it is tighter.
Old Jan 28, 2005
it felt looser for some reason? I know the back end has more of a wobble than before. I could turn at 45-50 90 degrees and it wouldnt skid as much as now. There is a difference, but not nearly as noticeable as the fron tie bar. the front one made a tremendous difference. The rear close to nothing, but a little looser for some reason? I bought it for the look in the trunk. It is right in front of my subs (since their facing forward) and it looks dope.
Old Jan 28, 2005
ajhdragon's Avatar
i have rsx sawy bars right now.
Old Jan 28, 2005
ajhdragon's Avatar
but thanks for the imput everyone.
Old Jan 28, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
basically, if you remove the carpet covering the mounting points, you can sort of tell 1 is not necessary for street. Cars like the RSX, old Civic hatches, Del Sol's, I guess would benefit more.
Old Jan 30, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
im gladi didnt get my Mr alex fuc.kin expensive one then..im over that phase of my life now.lol
SugarRay
Dec 13, 2001 09:58 AM
Daniel420
Dec 4, 2001 08:46 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
CapYoda
Nov 20, 2001 10:36 PM
CapYoda
Nov 11, 2001 05:17 PM
