KYB Vs. Tokico
Old Jan 25, 2005
thecheat's Avatar
thecheat is an unknown quantity at this point
KYB Vs. Tokico
I'm looking at the tokico D-spec and KYB AGX. Anybody who has experiance with either, how do you like them or how do your friends like them? how is the adjustment? How is the fit? If you have a girlfriend or boyfriend that has ridden in you your car how did they like them befor and after. anything at all will be helpful. thanks
Old Jan 25, 2005
I've heard enough about both to convince me to get agx.
Old Jan 25, 2005
civicvtec1ps's Avatar
Search and Learn
Kyb agx's front strut's knuckle size is specifically made for 01-02 models,14mm.
In order to fit on 03+ models, you will have enlarge to 16mm hole, just fyi.
Old Jan 25, 2005
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
agx's
Old Jan 25, 2005
fuzzylogic426's Avatar
fuzzylogic426 is an unknown quantity at this point
a member on here told me that the agx's fit the 03+ up without modification.
Old Jan 25, 2005
PunkingCivic's Avatar
I need TP for my bunghole
if you get the kyb's please post pics so I can put them on my web site.
I don't have a pick of them yet
Old Jan 25, 2005
thecheat's Avatar
I have an 02 so either will fit fine. how about ride and damping?
Gearbox, what have you heard that swayed you? I cant find much that seems usefull.
Old Jan 25, 2005
Ledbelly's Avatar
Im the man in the box
I use tokico blues and i love em
Old Jan 25, 2005
FaiJai's Avatar
FaiJai is an unknown quantity at this point
okay......so which its us back with this question.....are AGX's actually out now? one of the members said he's got them off tire rack. 1 dude out of how many members?? if you got agx's post some pics please ! =)
Old Jan 25, 2005
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
I plan on ordering 4 corners of KYB AGX to use with the H&R Sport springs that have been sitting in my basement for 2 years or so. This will happen as soon as Uncle Sam cuts me a check. I'll be sure to get some pics when I get them.
Old Jan 25, 2005
dvsdara's Avatar
dvsdara is an unknown quantity at this point
AGX's have been out for a couple of months now. People aren't raving about them as much as they did Tokico. I honestly don't know why though. I've had the AGX/H&R's on for about two weeks now after swapping them in for the B+Gs that I had on before. I have an 03 by the way and yes, I did have to mod it to fit. You can take it to a local shop to get it done. It'll take only a few minutes to enlarge the bolt holes to fit. My mechanic used this drill bit that had many different sizes on it as the hole gets bigger. He said it went all the way to 11/16. As far as how the ride goes, its very nice for us daily drivers. Don't forget that these have adjustable dampening. I picked up my fiance from work after getting them installed and she was happy about how the car felt compared to the B+G. That's also cuz I was slammed when I had those on. Anyway, AGX/H&R's are probably the best setup that I've had on this car so far. I also had them on my old accord too. You won't go wrong with them.
Old Jan 27, 2005
flipbagz's Avatar
Go Pistons!
flipbagz is an unknown quantity at this point
just wondering,, y did u get rid of ur B+Gs?
Old Jan 27, 2005
I plan on getting the agx for prokit, but not for a while since money is tight. At least we know they're out now.
Old Jan 28, 2005
jturbolx's Avatar
jturbolx is a jewel in the roughjturbolx is a jewel in the roughjturbolx is a jewel in the rough
if anyone wants a gb on agx's let me know
Old Jan 28, 2005
maybe in the spring?
Old Jan 28, 2005
prccivic's Avatar
agreed....i would be down for a group by in the spring...say like middle of april-ish is when i will have the funds
Old Jan 28, 2005
jturbolx's Avatar
ok i will look into and talk to some people and see how cheap i can get them
Old Jan 28, 2005
Zzyzx's Avatar
Autocross Junky
Ride qualitly wise, your better off with teh Tokicos, Handling... KYB.
BUt if I had my choice I'd go Koni, they well perform better then both. (handling)
Old Jan 28, 2005
but the agx are adjustable and they'll still be stiffer than tokico? How does that work?
Old Jan 28, 2005
Zzyzx's Avatar
Autocross Junky
ITs the Valving range... not all shocks adjust the same ammount or the same range, Be it Low Mid or High speed valving. And Tokicos Tend to be on the softer side of valving Any way. And You are only adjusting The Low to Mid speed Rebound setting on the KYB's, which has more to do with handling then it does with ride quality.... Plus KYB's are known to have Relitivly High Bump settings.... making for a little rougher ride. (bump deals more with Ride quality) The plus side as far as a street damper is that the D-Spec adjust both Bump and rebound... So in theory, Since Tokicos are known to be on the Soft side of performance dampers, you could possibly assume that the D-Spec would be substantually softer then the KYB's as far as Ride quality is concerned. Especially since you control both the bump and rebound..
But i could be wrong as I havent found any Shock Dynos for the Tokico D-Spec, but if they follow the general design of the Illuminas then the above should be true.
Old Jan 28, 2005
cool. well I need to wait anyway. So prolly stick with d-spec (is it out yet for our cars?) or the hp.
Old Jan 28, 2005
thecheat's Avatar
yeah thats one of the reasons I have started leaning D-spec. I got a ride in an old peugot 505 turbo race car and it had really soft bump and realativly stiff rebound, the thing drove so nice and we could go so fast cause bumpy *** canyon roads just didnt upset the car like they do on mine. So I have been thinking that the softer bump of the d-spec might be a huge asset
Old Jan 28, 2005
2K1Civic17"Gabe's Avatar
Tokicos seem pretty soft at times. Smooth roads are just completely awesme, like your floating on a cloud. A lot of really bad pothole ghetto town roads, can suck. They are still soft though, You feel a bump, but it isnt as bad as stock, more control, and Youcan tell from the feeling it is sort of like a BMW. When they hit a bump, the car doesnt move, but the wheel flies up into the fender. They are a very nice ride, my dads GF really loved the ride of tokicos. She thought they were like a cadi? Very similar to how my dads CTS felt on bumps though. HE had 20s on there though
Old Jan 29, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
well i was told i should get the tokico blues for my eibach sportlines... now i dont know what i should get...
Injen
Old Jan 29, 2005
wait for the d-spec
Old Jan 29, 2005
injencivic's Avatar
d-specs are gonna adjustable right? wonder how much they are gonna cost?
Injen
Old Jan 29, 2005
more than tokico (maybe $500?), but worth it for adjustability. I don't wanna slap on the hp and say oh ride sucks now what?
Old Jan 29, 2005
Search and Learn
Injen
It's adjustable and it's out for sale already,
Cheapest price I've seen was $550 on ebay,
Old Jan 29, 2005
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
I've got the HP's + Neuspeed Sports and I can tell the HP's are a bit soft for the springs. If i had the choice to do over again i'd go with the AGX's. This is not to say that the HP's are bad shocks, but i think they're not particularly suited to some of the stiffer spings. They were perfect with stock springs and i'm sure they'll do okay with H&R's and the like.
Old Jan 30, 2005
injencivic's Avatar
i think i will stick with the tokico blues like RobClark recommended me..
injen
