Upper Mount Q
Old Jan 2, 2005
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
Upper Mount Q
I have 03 civic, i understand i need 01 or 02 upper mounts in order to install my tein basic.
369032 Part 9 (BEARING, FR. SHOCK ABSORBER MOUNT) $13.98 X 2
369034 Part 10 (MOUNT, R. FR.) $23.45 X 1
369034 Part 11 (MOUNT, L. FR.) $23.45 X 1
My Q is, what about the rear? can i reuse my 03 mounts on the rear?
thx
Old Jan 2, 2005
bgoetz's Avatar
bgoetz is an unknown quantity at this point
the teins should come with rings that will allow it to fit on your 03. They started including that in all of their newer shocks for 01-04 awhile ago. Call tein and they can help out or send you the pieces to make them fit.
Old Jan 2, 2005
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
^.. yup agree with him.. i just did an install on them for a few people and they now come with it
Old Jan 2, 2005
robbclark1's Avatar
Retired suspension supermod.
The rears have a mount attached to them
Old Jan 2, 2005
jttegx's Avatar
OMNES AD UNUM
so tein is now offering mounts for the fronts to fit on the 03+ model civics? or were you guys talking about the rears only?
Old Jan 2, 2005
put it this way... whenever you order a tein kit it now comes with everything to install the springs on any car 2001-2005
Old Jan 2, 2005
bgoetz's Avatar
yeah, you have both the parts for the 01-02 and the parts for 03-04. So if you did not get both call tein and they will provide them
Old Jan 2, 2005
Yoyoio's Avatar
thx for the input guys. i bought this tein basic from my friend, so it does not incl whatever you guys mention above. It was bought a yr ago.
so, can i take aprt my stock rear and use those mounts?
also, how does the "NEW" tein work with the 01/02 14MM and 03 16MM?
Old Jan 3, 2005
basically you can just go to a junk yard and looked for a wreck 01-02 and take the upper mounts from it.. if not call tein and they might send it to you for free if you have proof of purchase.. then if that fails you can just buy it from tein
Old Jan 19, 2005
taz757's Avatar
I ordered a set of Tein SS and I didn't get any upper mounts or anything. For the fronts or the rears. I don't want to reuse my old mounts from my 01, as I think they're worn. I just want to replace them.
What am I going to need to buy from Honda to install these?
Do I just need 9/10/11 from this picture? That's the front L/R mounts.
What do I need from the rear? Just 9? I'm not too sure ...
Old Jan 19, 2005
robbclark1's Avatar
For the rear you don't need anything.
If you don't want to take apart your stock shocks, then I think you will need 9, 10, 11 and 13. Don't quote me on that.
Old Jan 19, 2005
taz757's Avatar
You sure I don't need anything for the rear? I was looking at them the other night, and it looks like I'm going to need some kind of upper mount still. I'll have to go home and take pictures.
Old Jan 19, 2005
peteriap's Avatar
peteriap will become famous soon enoughpeteriap will become famous soon enough
Call Tein tech support at 562-861-9161 and they will give you all the info you need. I could call them for you but it would probably be easier if you explained your situation directly to them.
Let me know if you have any other questions.
Old Feb 17, 2005
Skylar1692's Avatar
Skylar1692 is an unknown quantity at this point
2001 HONDA CIVIC EX SEDAN SHOCKS/STRUTS & SPRINGS
APPLIES TO 2001 HONDA CIVIC EX SEDAN
I just called TEIN tech support and they said depending on your driving style highway, stop and go, improved or unimproved road driving, before you reach 100,000 mile the mounts should be replaced only if they look worn otherwise they are fine. I currently have on order the TEIN High Tech Springs so I was curious myself.. I will post pics once they arrive with a DIY on this since so many people are asking for it. The parts you would need to replace are as follows...
MOUNT, R. FR. - 369033 - $23.53 part
MOUNT, L. FR. - 369034 - $23.53 part
BASE, RR. SHOCK ABSORBER MOUNTING - $18.97 part # 369097
BASE, LR. SHOCK ABSORBER MOUNTING - $13.83 part # 369098
These are prices and part #'s from http://www.hondaautomotiveparts.com/
Rubbers should also be checked prior to installation, check to see if cracked, dryrotted etc..
I hope this helps some of you.
Old Feb 17, 2005
Yoyoio's Avatar
i'll look into that... thank you
Old Jun 25, 2005
kasimmmmm's Avatar
i'm looking for 02 mounts for my teins too but why are there way more parts listed in this thread http://www.7thgencivic.com/forums/sh...light=02+mount are the rest necessary?
Old Jun 25, 2005
kasimmmmm's Avatar
anyone?
Old Jun 25, 2005
because thats what the complete upp mount consists of
Old Jun 25, 2005
kasimmmmm's Avatar
but the front only requres 2 parts, but rear requires so much more.... are those necessary or can i use the parts from you stock?
Old Jun 25, 2005
flipbagz's Avatar
Go Pistons!
flipbagz is an unknown quantity at this point
use ur stock parts for the rear,, for the fronts,, just read the instructions so u will know w/c color to use,, gold/green,,
mgrantaz
General
May 2, 2022 05:40 PM
twd000
Oct 4, 2015 12:52 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
FistRock
Sep 4, 2015 08:00 PM
