tie bars on a 04 vp
Old Dec 26, 2004
matt86's Avatar
matt86 is an unknown quantity at this point
tie bars on a 04 vp
since the 04 vp's don't have sway bars from the factory how would you mount an aftermarket one? THanks
Old Dec 26, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
You need to buy the Progress Swaybar mounting kit.
Old Dec 27, 2004
matt86's Avatar
it sounds like more trouble than its worth
Old Dec 27, 2004
Zzyzx's Avatar
Autocross Junky
That depends on if you want the car to handle better or not....
Old Dec 27, 2004
snowboreddave's Avatar
snowboreddave is an unknown quantity at this point
my friend that works at progress just told me last weekend that the stock 05 civics are coming out with a 25mm rear sway!!! just a little FYI..
Old Dec 29, 2004
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
Not necessarily, if you wish to autocross the car and want your car to do more oversteer or less oversteer, then by having the rear sway bar you can tune it to do so. I've seen the progressive rear sway bar mounting kit, I just don't like the way the end links mount. I would just assume buy lower control arms that already have the mounts on them, then drill the holes for the mounts on the cross frame and thread them. for a factory fit and finish.
Old Dec 29, 2004
ty.barrack's Avatar
ty.barrack is an unknown quantity at this point
I have stock sway bars front and rear, i suppose they do some good, but yeah I would do both ends if I were you I think I've seen the Progress one referred to above, just do it.
Old Dec 30, 2004
Jap-Euro Fusion
Somehow, I highly doubt that.
2 reasons... 1. The RSX-S only has a 21mm bar, why would they put more reas bias in the Civic if the RSX is supposed to be the sportier car?
2. A 1" bar in the rear with the stock springs would be a deathtrap to the average granny driver
Someones full of it, or they went back to the 25mm FRONT bar.
Old Dec 30, 2004
yeah, im sorry, it went to 21mm.. so progress is making the 25mm.. my bad, got the numbers screwed up..
SammySC
121
Apr 7, 2017 07:43 PM
Raiool
Oct 1, 2015 10:42 AM
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Viczhou
Sep 2, 2015 07:55 PM
