skunk2 ? rear not that low!!!
Old Dec 22, 2004
henzoketchup's Avatar
henzoketchup is an unknown quantity at this point
Question skunk2 ? rear not that low!!!
i have skunk 2 coilovers and its good . i can slam it in the front but in the rear i max it all the way and its not that low? i can fit a finger from my body to the tire>. what can i do to lower it even more ? please help...
Old Dec 23, 2004
Mr.Modify's Avatar
hmmmm strange.....i can slam my rear lower then my front with GC's but i don't have any expeirence with Skunk 2 coilovers. Not quite sure it should be the other way around......did you install?
Old Dec 23, 2004
sw388integra's Avatar
yeah, gc's will go lower than skunk2 (rear)...i still have mine on my car, and it's all the way down on all 4 corners and the rear doensn't tuck like the front...oh well, cut some of the spring if you want lower...?.....
Old Dec 24, 2004
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
i've had the same problem. if you adjust the rear camber so its sits a little negative, it'll go lower but i dont think you;d want that =|
Old Dec 25, 2004
18inchpride's Avatar
18inchpride is an unknown quantity at this point
did you ever think that they were put on the wrong way! you may have put the rear spring on the front, and the front spring on the back! i did that by accident last time i changed up my suspension! The thikness of the springs are a bit different, jack the car up! it will say the diameter on the coil! HENCE the larger thicker should go on the front! (common sense) but honeslty thats prolly the problem!
Old Dec 25, 2004
D17thgen's Avatar
^false. the smaller, shorter set of springs go on the front. the skunk2 for civic 01+ comes with only 2 top plate mounts and those 2 top plate mounts belong in the front with the 2 smaller shorter springs...
the rears are the taller, bigger 2 (two) which do not have top plate mounts. however, all 4 do have perches (since they are coilovers) dur lol
Old Dec 27, 2004
technick03's Avatar
technick03 is an unknown quantity at this point
switch em' , had mine professionally installed, called skunk 2 about this problem and pondered it for awhile. Ended up putting fronts on back and backs on front, slammed all the way around enenly and no problems. Had it like this for just over 1 year, springs in front bind sometimes, but I've heard that problem with other brands of springs and coilovers - trim bump stops too. Hope this helps. I know it doesn't sound like the right thing to do, but it's the only way to get an even drop if you want it slammed and personally I think the springs should be installed this way. GET A CAMBER KIT TOO IF YOU DONT ALREADY HAVE ONE - SPC - or you'll be buying new tires every 6-8 months.
edspyhill09
Jun 12, 2016 02:45 PM
S.Klinck
Feb 10, 2016 02:19 PM
Jeffdp
Aug 5, 2015 11:38 AM
S.Klinck
Jun 11, 2015 10:27 PM
