dropping car by adding weight...
Old Dec 19, 2004
infinite's Avatar
infinite is an unknown quantity at this point
Question dropping car by adding weight...
...is it safe to add about 100 to 160 lbs of weight in my trunk in the form of, lets say, car stereo equipment? i noticed that my rear sits about a quarter to a half an inch lower when i add this weight. is this safe or will this be bad for my shocks? i'm lowered on neuspeed sport and tokico blues.
Old Dec 19, 2004
2K1Civic17"Gabe's Avatar
how low is your drop on neuspeeds? Im on tokicos, and I have goldline springs (2" or so) My ride is fine, so if the drop isnt as low as mine, you should be fine. springs are a 1.75 drop, but is at least 2" from when they were first put on, and sagged just a little bit. My suspension is very tight/stiff with a little over 2" though.
Old Dec 19, 2004
It doesn't work unless you leave the weight there permanently. We had my trunk loaded down with stuff for a week and when it came out the ride height went back to normal (it was slammed almost with the stuff back there).
Old Dec 20, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
doesnt tokico not recommend more than a 1 and 3/4 inch drop on their struts?
Old Dec 20, 2004
PunkingCivic's Avatar
I need TP for my bunghole
you couls always go with a beefier rear sway bar too.
That might help
Eibach has a one inch thick rear sway bar.
Old Dec 20, 2004
SIinthesky's Avatar
SIinthesky will become famous soon enoughSIinthesky will become famous soon enough
A rear sway bar won't stop the car from sitting any lower. It will stop it from rolling more around the corners. I would be cautious. When the sturts are compressed some all the time it shortens the lifespan of them. You might want to consider a stiffer spring.
mikemc422
Aug 9, 2018 05:41 PM
tylerginevan
Apr 27, 2015 12:29 PM
alexkharden
Apr 23, 2015 07:13 PM
tattedlariat
Apr 17, 2015 03:26 AM
ImmortalEX
Oct 31, 2001 10:00 PM
