Check out My Alignment Results, Need Help?
Old Nov 26, 2004
chicohonda02's Avatar
Since 2002 Baby!
Post Check out My Alignment Results, Need Help?
Read these results and let me know how bad my camber kit is needed. I sorta understand the measurements. Is there more to it? So now that I need a camber kit, does brand realy make a difference? A camber kit is just a camber kit, right?
Old Nov 26, 2004
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
Your camber is not even that bad as far as I'm concerned, but thats only because I really dont care about my tires that much. You will wear some tires out faster than normal certainly, so if thats a major conern of yours then get the camber kit right away.
Old Nov 27, 2004
jturbolx's Avatar
jturbolx is a jewel in the roughjturbolx is a jewel in the roughjturbolx is a jewel in the rough
yeah tire wear won't be that bad because toe wears more than camber i wouldn't worry about it
Old Nov 27, 2004
Since 2002 Baby!
but I have notice that my tires are wearing down, but considereing that I do alot of driving.
Old Nov 27, 2004
robbclark1's Avatar
Retired suspension supermod.
Do you rotate them every 3 months? Where are the rear specs? The alignment people will tell you that you can't adjust the camber in the front. They don't know what they are talking about. Tell them to undo the top crash bolt and push the top of your wheel out. That should get you a .25-.5 less camber.
Old Nov 27, 2004
streetglower's Avatar
I agree with robclark, I just finished a cource in school dealing with alignments and if it is out a bit, it isnt a big deal, but they should be able to change that setting by half a degree or so.
Old Nov 27, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
The're fine.
I had mine intentionally aligned to -2.0 in the front and -1.0 in the back yesterday. Camber doesn't wear tires. Toe does. It looks like they set your toe, so you're fine.
Old Nov 28, 2004
Sorry for off topic, but with a 1 inch drop do I even need to get a camber kit and alignment? How is toe adjusted?
Old Nov 28, 2004
robbclark1's Avatar
you probably won't need one, but they are always suggested. Toe for the front is adjusted using the tie rod. Toe for the rear is adjusted using one of the bushing bolts and there is not as much adjustment in the rear. Front toe is more of a concern.
Old Nov 28, 2004
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
The front camber bolts are like 25 dollars. With them you could get the camber on the fronts perfect.
It all depends on if that small amount of money is worth it being within specs.
Old Nov 29, 2004
Since 2002 Baby!
I don't know why I didn't notice any rear specs. Yesa I rotate my tires every 3 months. They told me that my rear needs camber kit bad, but funny how, they didn't print anything out for me, huh? I'm gonna go question it.
Old Nov 29, 2004
2K1Civic17"Gabe's Avatar
My front are -.8 which is within, they look perfect. My rears are at -2.8, -2.3, and I have driven about 1200 miles since lowering, no prob on tires. Toe is ok I believe, I forget. Camber is off pretty bad in rear, but not enough for me to care about until after the holidays
HX
Dec 28, 2001 10:04 AM
Micks2K1
Dec 6, 2001 07:09 PM
delacampos
Nov 7, 2001 09:18 PM
dubbc
Nov 7, 2001 02:24 PM
GoofyLogicInc
Oct 25, 2001 09:50 PM
