Front 16mm sway bar or 26mm bar
Old Oct 30, 2004
ctv's Avatar
ctv
ctv is an unknown quantity at this point
What would be better the 16mm solid Honda front sway bar or the 26mm hollow Honda front sway bar???????
Oh better as in stiffer.
thanks
chris
Old Oct 31, 2004
Intruder's Avatar
Intruder is an unknown quantity at this point
The 25.4mm front bar is significantly stiffer. Why are looking for a stiffer front roll bar?
I ran the 15.9mm front bar for a few months with the 19mm rear....
Old Oct 31, 2004
skarteez's Avatar
skarteez is an unknown quantity at this point
hmm ive been wanting to do the same to my 2004...
i kidna hate how "rollly" the front is while takin a turn kinda fast, makes me feel uneasy and squishy (haha...?). i guess swapping out the 16mm front for the 25.4mm and then upgrading to a really thick rear sway with new endlinks, wouldnt that be not too bad?
Old Oct 31, 2004
ctv's Avatar
ctv
i have the 19mm RSX rear and it helps alot so i want to make the front stiffer
I recently added Prothane rear sway bar bushings and its really stiff now
i just ordered the bushings for the front bar that 26mm
i hope to have a very stiff front end
Old Oct 31, 2004
nindoo's Avatar
Why is my vagina bleeding?
I don't know if the 2004 have a 25.4 front. The 2002 has it but afterwards they made them smaller.
The 2004 has a 15.9 mm sway bar.
If you currently have 19 in the rear so your rear is thicker than your front. Are you having a hard time controlling the car? If your car is oversteering too soon than a thicker front is needed to increase understeer.
Its hard to say what is best.
Old Oct 31, 2004
Zzyzx's Avatar
Autocross Junky
Nindoo more or less has the Idea.
ctv, what do plan on doing with the car? General Street use? Autocross? Open track? Dragracing???
Just be aware that if you get a stronger front anti-roll bar, you will have Less body roll at the cost of Increased understeer.
Old Nov 1, 2004
ctv's Avatar
ctv
I cans stand how the car a 2004 coupe is so sloppy on cornering
i got a RSX rear 19mm bar to replce the puny 12mm
it made a nice difference, so now i am upgrading
the front to 26mm from 16mm
i use my car for general use and like the suspension Stiff.
But my Question is, the 2004 16mm bar on my car now, will the 26mm from the 2001 coupe be the same stiffness since its Hollow???????
Old Nov 1, 2004
Zzyzx's Avatar
Autocross Junky
Slopy as in how?
The 25.4mm bar will be substantually stiffer then the 15.9mm bar. I should konw, I swaped my 25.4mm bar in favor of the 15.9mm bar.
My current Anti-roll bar set up is this.
03 OEM 15.9mm front
Hotchkis 25.4mm 2 point Adjustible rear. (I may be going to the Hotchkis 27mm rear bar if I cant get the rotation I want with alignment settings at this point)
Old Nov 1, 2004
ctv's Avatar
ctv
[QUOTE=Zzyzx]Slopy as in how?
QUOTE]
ok thanks thats what i wanted to know, i didnt know if , since one is hollow
and one is solid that they would actually turn out to be equal
skoppy and too much sway when cornering
Old Nov 1, 2004
Zzyzx's Avatar
Autocross Junky
Like I said, a larger front bar will help reduce body roll at the cost of increased understeer. so you may find your self shoping for a larger rear bar soon.
Old Nov 3, 2004
civictuner's Avatar
civictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trustedcivictuner should not be trusted
im gettin the.....
DC5R Rear Sway Bar 22mm
and can any1 tell me what a good OEM front sway bar would be?? has to be direct bolt in and big as in 24mm at least
Old Nov 4, 2004
Zzyzx's Avatar
Autocross Junky
Originally Posted by civictuner
im gettin the.....
well the 01 coupes had a 25.4mm front bar... but I have to ask... what makes you think you need a larger front bar? Have you driven the car with the larger rear bar on it?? why spend $$ on a part that you may not need or want in the long run?
Old Nov 4, 2004
someguy's Avatar
someguy is an unknown quantity at this point
my 02 sedan has a 25.4mm front bar. and a puny 12mm rear bar....you can def. see the difference in the two. just giving more input on what cars have what parts. to help widen his search.
Old Nov 4, 2004
ctv's Avatar
ctv
I hope to install my new 25mm front 02 coupe front bar this weekend with new e/s bushings.
I noticed it Hollow, so it will save some weight as well
Old Nov 4, 2004
civictuner's Avatar
yea the 01 front sway is 25.4mm heres a link: http://automobiles.honda.com/certifi...ModelYear=2001
and the rear sway bar off a DC5R (22mm) link: http://www.aj-racing.com/Products/JD...5/DSCN2903.jpg
so would a 2001 front (25.4mm) and a DC5 rear (22mm) be a good setup?
Old Nov 4, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
would a big solid front bar be good for drag racing or would a smaller front bar be better? (what about rears?)
Old Nov 4, 2004
PunkingCivic's Avatar
I need TP for my bunghole
Here is a link to some Honda / Acura sway bar specs
http://www.sceniccityonline.com/arti...ybarspecs.html
Old Nov 4, 2004
Zzyzx's Avatar
Autocross Junky
A good setup for what? Autocross? Open track? Street? Need info! as all three will have different setups.
aznboysrfr, for better straight line stability a larger front bar would be usefull.
Old Nov 4, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I read something either you or boilermaker posted a while back ... something about stiffer rear springs (or was it shocks) that would absorb a lot of the shock in a hard launch? ... someone refresh me ...
Old Nov 4, 2004
Zzyzx's Avatar
Autocross Junky
you can adjust your dampers(shocks) to give you better launches, by controlling the speed in which weight is transfered off the drive wheels.
Old Nov 4, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
^ fronts? or rears?
me with suspension =
Old Nov 4, 2004
civictuner's Avatar
all three
Old Nov 4, 2004
civicvtec1ps's Avatar
Search and Learn
all three
LOL
Old Nov 5, 2004
civictuner's Avatar
Originally Posted by civicvtec1ps
LOL
YEAH I WANT ALL SPECS 4 THREE
1. AUTOCROSS
2. OPEN TRACK
3. STREET
Old Nov 5, 2004
ctv's Avatar
ctv
ok i did the swap
it feels alot better
BTW the stock front sway bar on a 04 is a 16mm Hollow bar
going to the 01-02 25mm holow bar is a grest mod
i also added e/s bushings front and back
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Makeice3498
Jul 2, 2015 11:13 AM
mrohitredd
Jun 9, 2015 06:37 AM
Rogelio Rey
May 24, 2015 08:30 PM
bsmiley
Apr 27, 2015 01:27 PM
