Creak Sound from LOWERING H-E-L-P!!!
I have a Eibach Pro Kit with Koni Yellows for the first 2 months all are fine. after that when I turn the wheel from left to right their's a CREAK sound, someone suggested to put wire wraps on the springs it worked for 1 day after that the F^&k^&g! sound came back! Do I need to take off the whole spring to install the wire wraps or is this sound coming from another source???
http://www.7thgencivic.com/forums/sh...d.php?t=179256
Did you index the springs and shock correctly? Did you do the install?
It was done by the dealer they even showed me how they cut the front strut to fit the Koni's, I even went to another shop to confirm if they did the correct job they said everything is done correct. I notice this is a recurring problem for some of 7th gen mem. does putting the wire wrap really going to help??? I'm planning to have the struts removed this week but i want to make sure first before I do it??
Sure, it might help. The best thing to do is to try to figure out where the noise is coming from. It took me a while before I discovered my insert was loose. What I did was put my front end up on jack stands and turned the wheels like I was steering, which help me isolate where the noise was coming from.
15EXCoupe
Jul 30, 2015 12:59 PM
mokkush
Jul 14, 2015 04:05 PM
Jul 12, 2015 11:54 AM
