Cutting rear dust boot
I have TeinSS and esterday my car started making a really loud cracking noise in the rear when the car went up and down....... I got worried and took it to my mechanic. Turns out it was the dust boot that got a little bent inside and was hitting the sping when it was moving.
We ended up cutting off about 2 inches of the dust boot and the cracking sound went away...... so in conclusion it was the dust boot making that loud cracking sound.
My question is this. I can see that my shock is a little exposed now because part of the boot was cut off. Is this a problem? Could dirt get in there and eventually mess up the shock?
The part that is exposed is the rod when it goes inside the shock......
Any deciently made hydraulic device has a cleaner ring on the piston seal. So no dirt should get into the shock body, nor should you have to worry about surface damage to the piston in the area of travel. I don't have any dust boots period and I've never had an issue.
I had that same problem, I went shopping at sams club and had my trunk filled with heavy stuff and hit a huge bump and the dust covers bottomed out, I cut them just enough so they still cover the shock rod when it is on the ground. Luckily I didn't have to take mine to a mechanic because I do all my own work, but at first I thought I blew my shocks, because it sounded horrible. Now there are no noises from the rear, its great!
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Nalmonte
Jul 22, 2015 09:08 AM
mistermenphis22
Jul 13, 2015 04:43 PM
OptimisticWay
Jul 10, 2015 04:31 PM
