Is this everything i need?
Old Oct 6, 2004
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
http://www.groupbuycenter.com/buy.aspx?id=17510
Is this Tein Type Basic Coilover everything I need to lower my car and have a good suspension system with a smooth ride??
Comes with:
Height Adjustable shock absorber x4
Main spring x4
Lower spring seat x4
Seat lock x4
Thrust washer x4
Bump rubber x4
Dust cover x4
Hook spanner x2
Instruction manual
If not, what else do I need (beside camber kit)
If yes, is it a good set?? anybody have this set up w/17's or 18's??
Old Oct 6, 2004
robbclark1's Avatar
Retired suspension supermod.
1) search for tein basic.
it is a good set up if you aren't racing.
2) read the suspension FAQ in my sig!!!
You don't need a camber kit, but if you want to save your tires then get one.
3) when you search for tein basic, you will see that you need new front upper mounts if you don't want to take apart your stock ones. You have to get '01 upper mounts. Don't ask me for part numbers because they are in TONS of threads, you just have to search.
