so whats better?
Old Sep 26, 2004
Danka02's Avatar
SICCMADE
Danka02 is an unknown quantity at this point
so whats better?
I always thought that sportlines gave you better handling than the pro-kit my friend told me otherwise saying that the prokit has better spring rates thus having better handling from the sportlines. I put my sportlines on and the car rails corners and looks great my back wheels are almost tucked and i have about a 1 finger gap in the front and my tires are 195\65\15's. Anyway
so seeing as my car is pretty low now from the sportlines and hearing that the pro-kit gives you almost an 1 inch drop wont the sportlines be better than the pro-kit?
Old Sep 26, 2004
robbclark1's Avatar
Retired suspension supermod.
yes, they are stiffer and drop lower. They SHOULD be better overall. At least I think so. The prokits aren't as stiff and don't lower very much.
Old Sep 26, 2004
Danka02's Avatar
SICCMADE
thats what i thought
Old Sep 26, 2004
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
however, just cause someone is low(some coil-over setups) doesnt mean you will handle better. if you use stock like spring rates(i.e. cut the springs) you will bottom out, as well as handle similar to stock
also, going too low will give you bumpsteer, and may make your camber more severe than any camber kit can fix
Old Sep 26, 2004
Danka02's Avatar
SICCMADE
i know that i'm just asking if the sportlines were better than prokit in terms of handling
Old Sep 27, 2004
robbclark1's Avatar
good point, but I was assuming he knew that. The sportlines, with a good set of shocks, should outperform the prokit. It isn't a drop that is too low.
Old Sep 27, 2004
flotsamm's Avatar
When I called up Eibach about my Sportlines, they mentioned that the Prokit in general was 10-15% stiffer over stock and the Sportlines were 20-25% stiffer over stock. If stiffer means better handling, then the Sportlines are better.
Old Sep 27, 2004
robbclark1's Avatar
I was actually told a little bit more. But whatever...you get the idea.
Old Sep 27, 2004
i agree about the sportlines handling better than the pro-kits, i wasnt arguing that. anyway, pics of your ride with the sportlines? gotta get some
Old Sep 27, 2004
Danka02's Avatar
SICCMADE
i will have some very soon i hope maybe in the next 2 days or so, my girls camera isnt that great the ones i took came out carppy
Old Sep 27, 2004
flotsamm's Avatar
Here's one of mine with Sportlines:
Old Sep 28, 2004
red x man
