How people drive when there car is so low
Old Sep 23, 2004
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
Today when driving i saw a nice ls 4dr integra with 17 inch rims,very lower all 4 tires all tug, i mean very tug in all you see is half the tires, all 4 of them is like this / \ camber. I just wondering it is sooo low can you actually turn with hiting the fender liner or fender. There really no point of lower it that much you can't even make fast turn without hitting something on your car.
Old Sep 23, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
you drive slow...thats how, and avoid speed bumps if possible
Old Sep 23, 2004
AnaRki's Avatar
DDC Representa
AnaRki is an unknown quantity at this point
slammed cars are pretty sick, just not to slammed.
Old Sep 23, 2004
civic01vtec's Avatar
maybe he was rolling on air ride
Old Sep 24, 2004
Mr.Modify's Avatar
just try it out for yourself man....eventually you'll learn
Old Sep 24, 2004
chicohonda02's Avatar
Since 2002 Baby!
honesty.
Old Sep 24, 2004
Nitto's Avatar
gone
Nitto will become famous soon enough
as long as you have good suspension, you can ride low. My car is beyond low...people laugh, but i dont care
Old Sep 24, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
^^ what he said.. w/ my B&G.... im perrfect im tucking all 3 tires and no probs
Old Sep 24, 2004
ferio's Avatar
ferio is an unknown quantity at this point
you'll get used to it after a couple of bumps here and there
Old Sep 24, 2004
hustlelikem0fo's Avatar
to tuck the rears peopel usually run a little negative camber..... when there is pressure applied to the wheels they camber in more under the suspension rebounds.
and yea, you get used to it....... driving slowly, carefully and if you see a speed bump pull a U Turn
Old Sep 24, 2004
i have teins basic and i drop that to max. my guess is 2.25 or lower with oem kit on 15s and i think is low enought for me. How your guys turn when your front is tug in, so much would it rub the inside of fender?
Old Sep 25, 2004
duyaknow's Avatar
duyaknow is an unknown quantity at this point
My drop is not even as low as some of you guys, but my midpipe under my car scrapes speed bumps.
Old Sep 25, 2004
baggedblue02's Avatar
baggedblue02 will become famous soon enoughbaggedblue02 will become famous soon enough
If I creep I can ride this low in the rear, the exhausts just starts to scrape if I move any faster. No tire rub though
Old Sep 25, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
^^^ ur front isnt low at all tho.... idk the rear looks like a kid w/ down syndrome at the retarded angle.. anywho.. idk.. i just dotn understand bags... my suspension rides like god and is low at same time.. so whats the benifit of bags..? ive driven in cars w/ emand they ride like ***/ tire wear like ****/air leak issues when lines not properly ran.
riley
Old Sep 25, 2004
Where to start... mine are strut bags and the ride is better than it was with the factory suspension. Its smooth at the right psi, and also will handle better than the factory if at the right psi. Having coilovers, I use to bottom out all the time, and the roads around Birmingham aren't the best either. Now I just raise it to a smooth ride. I also had my hangers on the exhaust broken off a few times by really bad dips turning in somewhere. No problem there anymore either. Took my time on the install so nothing rubs and no air leaks. No camber either if at the right psi so it will sit low when parked and still keep the tread on the tires. Girls also seem to get a lot bigger kick out of it than they ever did with just coilovers
Old Sep 26, 2004
SlammedBlueEM2's Avatar
All Eyes On Z
Drive slow? No way! But really, I've never had a problem going fast while being slammed. I think you really have to go fast in stupid situations to suffer. Some situations going slow can't be helped. I recall scraping the front subframe when a protruding part of the pavements came up in the middle of the lane, and since the pavement was uneven making my car bounce while slowing down, I inevitably scraped it at 2mph. I was on GCs.
Another thing you don't want to do (no matter how you're lowered) is run over a rock the size of your fist. You'll be like, "WTF?"
It looks like the older Civics and Integras can fill their wheel wells easier (while still having adequate ground clearance) than 7th Gen Civics - running on 15s and the smallest profile possible. That's the only issue I have with lowering a 7th Gen Civic.
However, right now I couldn't be more satisfied with the ground clearance I'm at Vs. the wheel gap my wheel/tire combo offer with my B+Gs. The only way I could fix the gap issue is get larger wheels with tires that have an adequate profile - OR get thicker tires for my 15s and that ain't gonna happen ever. Bags? Never.
I might just go back to a more customizable suspension in the future - Ground Control/Koni Yellows.
The lowest car I've seen was this 7th gen on bags that's in NorCal. He's on 95 GSR rims on 195/50-15s tucking the tires. One pic I saw his car rolling like that. Talk about ridiculously low. All I want is to completely fill the wheel gap... not tuck the tires.
Old Sep 26, 2004
Low profile tires make for more of a rough ride than the suspension over little bumps
Old Sep 27, 2004
All Eyes On Z
True, however.... you can have stock sized tires with stiff springs and still have an even more uncomfortable ride over uneven pavement. You just won't risk bending a rim in the process.
I recall a guy with 205-35-18s on Hayames.
Old Sep 27, 2004
scorpion232's Avatar
scorpion232 is an unknown quantity at this point
angles it's all about the angle and speed
Xuhme
21
Aug 7, 2023 03:40 PM
tylerginevan
Apr 27, 2015 12:29 PM
smmahan
Apr 15, 2015 08:17 PM
CiViCPrAnInG2k1
Nov 1, 2001 03:47 PM
Rachels2k1
Sep 19, 2001 01:54 AM
