Tokico question for 03
Old Aug 26, 2004
dvsdara's Avatar
dvsdara is an unknown quantity at this point
Are there any mods required to fit the Tokicos on the 03's? I only see that the application lists 2001-2001 so I just want to see if there is anything that I'll need to do to fit them.
Old Aug 26, 2004
gaugeof12's Avatar
gaugeof12 has a spectacular aura aboutgaugeof12 has a spectacular aura about
The back will fit fine BUT on the front you will need to drill the 4 knuckle bolts on each strut from 14mm to 16mm. Also since its designed for an 01-02 your bumpstop will be too large, you will need to hold it up with a ziptie, some wire, ect...
Old Aug 26, 2004
dvsdara's Avatar
Thanks, I guess its not too much work for it to fit. It's not a problem that the bumpstop is too large right? I know you said to hold it up with a ziptie, wire, ect... but as far af performance wise, no issues?
Old Sep 4, 2004
jttegx's Avatar
OMNES AD UNUM
how should it look after the bumpstop being held up with a ziptie? any photos?
Old Sep 4, 2004
gaugeof12's Avatar
The red circled part is what has to be drilled. The bumpstop (the black rubber piece against the strut body) should be held up at the top of the piston (silver piece). This particular bump stop has been cut as well.
Old Sep 4, 2004
Decamo's Avatar
Decamo has a little shameless behaviour in the past
In that pic you say the bump stop has been cut?? Isn't the bump stop those two black bulges? I think you just trimmed the boot.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
junkyardguy
Sep 2, 2015 06:07 PM
martinsmartin
Aug 15, 2015 07:34 PM
