installing front camber
Old Aug 22, 2004
Seabass's Avatar
Seabass is an unknown quantity at this point
hey everyone, ok im installing my hayames and my camber kit, but i dont know how to install the fron camber kit, ok its a little bolt...does it go in the top bolt or the bottom ont(where the hayames attach the brake assembly) and how does it work...how do i adjust the degree of camber? thanks.
Old Aug 22, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
im not sure if it goes on the top or bottom, but i do know that it has a lobe on it, so you can change the camber by turning the bolt. It pushes the wheel out at the largest point in the lobe. An alignment shop should be able to do it for you!
edit: i have the ingalls camber kit!
Old Aug 22, 2004
Seabass's Avatar
so anyone know if its the top or bottom? Thanks.
Old Aug 22, 2004
streetglower's Avatar
it goes in the top
here look
http://robearracing.com/pd_spc_front_camber.cfm
Old Aug 22, 2004
VNlilMAN's Avatar
The Standard One
http://www.specprod.com/PROD_DIR/C_P...txt&cmd2=81260
it goes on top. but then it might not work properly with hayames. hayames come with a slotted hole so that you can adjust the camber using that. in short, you dont really need a camber kit for the front for hayames
bsmiley
Apr 27, 2015 01:27 PM
bo_red
Apr 23, 2015 10:09 PM
ernhole1
Dec 6, 2001 12:05 PM
SneakerPimp
Nov 3, 2001 10:57 AM
ImmortalEX
Oct 31, 2001 10:00 PM
