Where can I get an 01 upper mount?
Old Aug 20, 2004
dvsdara's Avatar
dvsdara is an unknown quantity at this point
Just like the question said, I'm wondering where I can get an 01 upper mount for my car? I have an 03. The reason why I'm looking for the 01 is for the B+G coilovers. I don't have them yet but I wanna get them.
Old Aug 20, 2004
PunkingCivic's Avatar
I need TP for my bunghole
Try here and the prices are really good
Also there are diagrams to reference to.
http://www.hondaautomotiveparts.com/...catdisplay.jsp
Old Aug 20, 2004
dvsdara's Avatar
Thanks!
Old Aug 20, 2004
518's Avatar
518
518 is on a distinguished road
For clarification, is the number 9 in the illustration is all we need?
Old Aug 20, 2004
dvsdara's Avatar
hmmm....I took a while looking at it. I thought it was 10? Not too sure either. I'd just grab 8, 9, and 10.
Old Aug 20, 2004
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
If I recalled correctly from reading one of the threads, you only need #9.
Old Aug 20, 2004
flotsamm's Avatar
#9 is the strut bearing...
Old Aug 20, 2004
518's Avatar
518
Yeah,but is that all we need?
Old Aug 20, 2004
dvsdara's Avatar
Looking at the diagram(sp), it seems right if we get 8, 9, +10. Like I said earlier too, I'm not the sure about it.
Old Aug 21, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
Which parts do we need then?
I am ordering a set of 01 uppermounts because I have terrible clanking from my Ground Control. Will the 01 uppermounts fix this?
Old Aug 22, 2004
dvsdara's Avatar
I don't know about Ground Control. I do know that with the B+G, its a flush fit with the 01 upper mount. With the 02+, it fits, but its just not a flush fit like the 01. I the TEIN coilovers are the same too. If you look at their website, its updated saying that 02+ will need 01 upper mount.
Old Aug 22, 2004
ZdS03Civic's Avatar
Im gonna order the 01 uppermounts as soon as I find out which parts I need.
Old Aug 22, 2004
beastiek2's Avatar
This cost me 1500 points
beastiek2 is an unknown quantity at this point
I got my uppermounts and bushings from an 01 for my 04 from Honda 90$
Old Aug 22, 2004
518's Avatar
518
From the illustration above, did you just get the 9 and 10?
Strut Mount is $30.92/each (number 9 in pic above)
Strut Bearing is $13.45/each (number 10 in pic above)
Old Aug 22, 2004
beastiek2's Avatar
Yea it was both, the whole upper piece got replaced. Tein emailed me the part numebers, which I no longer have sorry....
Old Aug 22, 2004
518's Avatar
518
Ahh ic. Regarding the p/n, its okay. I will order it through a website where nio p/n is needed.
Old Aug 22, 2004
ZdS03Civic's Avatar
so parts 9 and 10?
Old Aug 24, 2004
obguam's Avatar
obguam is an unknown quantity at this point
Here is a list of parts for Teins (& B&G) to fit 02+, from an old thread:
Front:
369032 Part 9 (BEARING, FR. SHOCK ABSORBER MOUNT) $13.98 X 2
369034 Part 10 (MOUNT, R. FR.) $23.45 X 1
369034 Part 11 (MOUNT, L. FR.) $23.45 X 1
Rear:
36557 Part 1 (WASHER, SHOCK ABSORBER MOUNTING) $0.27 X 2
22692 Part 2 (COLLAR, SHOCK ABSORBER MOUNT (DUFFY STEEL PARTS) ) $0.45 X 2
369095 Part 8 (RUBBER, SHOCK ABSORBER MOUNTING) $4.74 X 2
369097 Part 9 (BASE, RR. SHOCK ABSORBER MOUNTING) $18.62 X 2
369099 Part 10 (AL, SHOCK ABSORBER MOUNTING) $3.80 X 2
369101 Part 11 (PLATE, SHOCK ABSORBER MOUNT) $1.79 X 2
369103 Part 12 (RUBBER, RR. SPRING MOUNTING) $9.71 X 2
369105 Part 13 (COVER, RR. DUST) $7.22 X 2
369109 Part 15 (PLATE, BUMP STOP) $2.15 X 2
However, majority of later posts said you don't need to replace rear oem parts, guess this is just optional. Hope this helps.
Old Aug 24, 2004
dvsdara's Avatar
Thanks for the clarification obguam. I searched a bunch of old threads also and just couldn't find it. Good find.
Old Aug 24, 2004
ZdS03Civic's Avatar
I guess I'll just order 9,10, and 11 even tho I have Ground Control. Hopefully it stops the clanking.
Old Aug 24, 2004
518's Avatar
518
Thanks, it did helped a lot for most of us.
Old Aug 26, 2004
dvsdara's Avatar
Ok guys, I just placed my order for a set of B&G's thru Jeff. Now I'm facing the question of, should I get the 01 upper mount? I know it's not necessary, but what you you guys think with the 02+?
mgrantaz
General
May 2, 2022 05:40 PM
twd000
Oct 4, 2015 12:52 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
FistRock
Sep 4, 2015 08:00 PM
