how low is your car REALLY
ThE FaMiLy SeDaN
measure from center of hub------bottom of fender
me
11 and 13/16" front
11 and 9/16" rear
overall ground to fender edge
23and 1/4" front
23and 1/2" rear
im j/w what people real drop is.. u might be on the ground but then.... u got smaller wheels etc...idk.. this is how i measure my drop..
someone w/ oem suspension and wheels
measure i wanna know oem.. MAKE SURE TO PARK ON LEVEL GROUND and measure b4 driving as to not heat up your tires and make them inflate more.
riley
me
11 and 13/16" front
11 and 9/16" rear
23and 1/4" front
23and 1/2" rear
riley
i dont know about those measurements you talk about, but i can tell you that i ahve about a pop can height off the ground in the front and half a can on the sides. im too lazy to measure
I have b&g's and Im riding 7 threads from the bottom of the coilover. I think that translates into about 3.25 inch drop all around.
In the front I am lowered 1.75" rear is 1.25"
Stock ride height is 26" from the base/bottom of the wheel to the edge of the fender.
I confirmed this with 2 Civics on even ground both on 15" wheels.
All Show No Go Sedan
I consider how low you really are by the wheel gap. When you get kits into it though, like xenon, which you and me have you might have to think about it differently though. Cuz the sideskirts almost drag the ground sometimes.
well, if we are talking about wheel gap, i have none in the rear cause im tuckin a bit and in the front i have about a finger gap. im on neuspeed race springs which are a 2.5" drop, but i think thye have settled to more around a 3" drop.
ThE FaMiLy SeDaN
im trying to find true drop height..
i cant even fit a sandal under my car... its lower than **** but im saying hub to fender shows actual drop... like when u drop a car the point ur "dropping" is ur hub.... yes... ok and a point of reference is the top of fender
im tucking all 4 tires
front tucks like 3/4" of tire above the fender
rear tucks 1" of tire above the fender
3.5" overall drop from stock height front..(measured hub to fender)
3.25 drop rear (hub to fender)
19" 215/35/19 nitto neogen
riley
riley
ThE FaMiLy SeDaN
modify
center of hub(w/ rim on springs compressed) to bottom edge of fender..
then ground to bottom edge of fender.
dont have some fat hoes in the car... noone in car measure..lol
if i have 4 people in back seat i tuck rim :-D
ThE FaMiLy SeDaN
2.4635 drop all around man im good and exact
14.25-11.8125 (.8125= 13/16)
14.0-11.5625 (.5625= 9/16)
over all is 2.4635 drop all around. man i knew i was good...am i good or what!
mine is defeniatly lower than 1.5" drop lol. neuspeed race springs are a 2.5" drop plus they sagged a bit. plus im tuckin in the rear, so i doubt 1.5" drop = tucking
if i remember correctly, i measured the stock wheel gap with 205-40-17s and it was around 3", so i think im more around a 3" drop.
ThE FaMiLy SeDaN
gap doesnt matter cause gap is relvant of tire size..
measure from the center of hub tofender would tell u exactly how far u rear control arms moved up.. which by definition is a "drop" someone needs to remeasure the oem height from hub to fender
Originally Posted by rijowysock
cool abmerop.. i wish some would check sedan i know their diff..
but u understand how im measuring right?
