coil spring isolators
Old Jul 25, 2004
sffree's Avatar
sffree is an unknown quantity at this point
if you put spring isolators on a set of springs cuz you think you have bind.. and it turns out not to be the springs.. basically, is there anything bad about having isolators on springs that don't need them?
Old Jul 26, 2004
VNlilMAN's Avatar
The Standard One
nope, nothing wrong..
you have coil bind? its probably badd bearings
Old Jul 26, 2004
sffree's Avatar
yea.. you'd think.. but I had the mechanic check that exact thing and they say the strut assembly is fine and the springs are indexed correctly...is coil bind a slight squeak? or is it something different? I hear mixed things and need a straight answer
Old Jul 28, 2004
SlammedBlueEM2's Avatar
All Eyes On Z
Coil bind occurs when a spring endures a high amount of compression the spring can't withstand. This can happen within various instances - say you have a full coilover set-up and your springs are preloaded (compressed) too much, and you run into a curb at say 40+ MPH. The impact would be too much for the already compressed spring causing it to bind.
Keep in mind your coil spring does not already need to be preloaded for that to happen. It can occur on any spring given the impact is hard enough.
Old Jul 29, 2004
sffree's Avatar
good to know... but I still need to know..
Does coil bind cause a 'squeaking' noise or a 'scraping/clanking' noise? I may not have coild bind...but I don't know what else it could be.. I'm lowered on eibach pro springs with koni yellows.. and some strut tie bars here and there... nothing major..so I don't know what could be causing it..
runawaykinms
15
Mar 22, 2019 10:32 AM
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
TheRiddicles
Sep 21, 2015 01:28 AM
RSKtakR
25
Sep 14, 2015 07:43 PM
