Upper Front/Rear Strut Bars?
Old May 30, 2004
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Hey everyone, I currently have a Front Upper Nuespeed Tie bar and im fixing to install an OBX rear upper strut bar that I have had for a while. Will box of these make a difference in the stiffness of my suspension? Thanks.
Old May 31, 2004
Civryder02's Avatar
Civryder02 is an unknown quantity at this point
i noticed a lot when i put on my spoon front strut bar and neuspeed x brace. i'll be soon buying the spoon rear strut bar. but yea ..... i noticed that when i take turns real hard my car doesn't jerk or slide around like it used to. it responds a lot better too
Old Jun 1, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
The rear will not domuch on our cars. The rear is very stiff to begin with do to the location of the strut mounts. Now, if you had a hatch like my 1990 Civic hatch you would notice a TON of help out of a rear upper strut bar.
Old Jun 2, 2004
sffree's Avatar
sffree is an unknown quantity at this point
spoon? really? they make a rear upper strut tie bar for 02 civics? Can someone refer me to a url or dealer? Thanks...
Old Jun 4, 2004
HondaLuver's Avatar
Its a celebration bitches!
newbie
Old Jun 4, 2004
sffree's Avatar
that's It?!?! newbie?!.. at least say something like "newbie! but the url is..." or sometin like that! sheesh.. Anyways.. back on the topic of the thread.. What is the consensus on the best available rear upper strut bar for the 7th gens? tnx
Old Jun 5, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
There arent much. There is Spoon, Cusco (RSX, but probably the best), APC RE works, and some generic ones. I read somewhere that Neuspeed did make a protoype rear bar for our cars but it didnt make much of a difference so they never made it for production.
Old Jun 6, 2004
sffree's Avatar
ah ok.. so there is a cusco one that'll fit.. which RSX model is it? Thanks!
Old Jun 6, 2004
ZSKCivic01's Avatar
Extreme Member
I had an OBX rear strut bar. Overall, there is a slight difference when I take corners, but for the most part it doesn't do a thing. It looks good though.
Old Jun 7, 2004
Any RSX. Get it from Rob (robearracing.coM).
But if you look at where the strut towers are, you can see it's right by the chassis....
a good example is a 350Z. They have a rear bar that sits right on the middle of the trunk. That will help more compared to our cars where the bar would sit where the chassis is. The older Civics have the bar in the middle of the trunk as well. Hope I'm making sense.
Old Jun 8, 2004
civicfrenchie's Avatar
civicfrenchie is an unknown quantity at this point
don't forget strut bars go after good tires,perf.shocks and springs and finally sway bars...that combination will put stress on your chassis and you will need struts bars.If you upgrade your tires it will put stress on your suspension (braking,cornering) so the next step is springs and shocks to get good balance (it will help in braking too cause reduce weight transfer in front (nose diving)) after that you will be able to take some corners very fast and maybe it will cause sway...go for the sway bars(choose the right one for your driving style) then go for strut bars to reduce chassis flex...tuning is a question of balance and we must follow some rules, question of having a good and fun car to drive and save $$$ for parts that don't give extras in performance...
Sorry for my english guys, like my name said, french is my first language(Québec)
I had to try in english cause your so cool and this site is awsome
Old Jun 8, 2004
tripledoublegs's Avatar
Euro-Spec
Originally Posted by HondaLuver
newbie
PW
Old Jul 17, 2004
duyaknow's Avatar
duyaknow is an unknown quantity at this point
That's some good info man and your english is very good. So I've been searching about rear strut bars because I was thinking about getting the Cusco rear, and reading up has made me think that the bar is unnecessary and mostly for show. I have a rear rsx sway, B&G, 17s with Falkens (tires get too expensive for Azenis though, so I'm on Ziex), and front and rear camber kits for adjusting. I think I'll be for sure getting a neuspeed front for sure. Just not sure if I'm gonna get a black or a polished one right now...haha.
Old Jul 18, 2004
thecheat's Avatar
thecheat is an unknown quantity at this point
rear upper wont do much, looks nice though. You would do better to spend the money on an RSX rear sway bar. That will make a world of differance and its a totaly stealth mod, no one will know its there till you tell them
Old Jul 18, 2004
clownprince's Avatar
Ricerus Maximus
The rear upper does do some good. I've noticed that the car doesn't 3-wheel on turns without it. And yes, I'm speaking of autox sharm turns.
Old Jul 19, 2004
thecheat's Avatar
mine three wheels without it. did it last night in the canyons
Old Aug 6, 2004
trance4mer's Avatar
trance4mer is an unknown quantity at this point
im lookin for that neuspeed strut bar too. dont know whether to get that first or that X-brace. what u guys think?? i got the rsx sway bar in already. what should i do next..
Old Aug 7, 2004
TMRakip's Avatar
TMRakip is an unknown quantity at this point
Nuespeed makes a Sway Bar/Tie combo, but it's rather pricey...I'm looking into one, but I'm not sure if it's worth the scratch...
Old Aug 8, 2004
trance4mer's Avatar
i already got the rsx sway bar. what im looking for is the strut bar.. and do i need a rear tie bar??
Old Aug 10, 2004
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
to be the devils advocate, i would like to challenge you on your way of thinking. for example, your suggestion is similar to this...
if you want power, you first buy the turbo, then buy the exhaust and remove the cat. then you buy bigger cams, then you raise boost to 20 psi for max power, then your tear the engine down and install high performance sleves, connecting rods, high strength bolts, etc...
what im saying is, wouldnt it be better to strenghten/re-enforce the chassis, before it gets "abused" by the additional forces the new suspension setup would produce?
just some food for thought
Old Aug 10, 2004
thecheat's Avatar
purely oppinion here so dissregard as you see fot.
Most of us arent good enough to get all the performance out of our cars as they sit on the showroom floor. I'm fairly certain that a totaly competent driver in a stock civic could destroy most of us in our modded cars just by driving it better. With that in mind, most mods are not going to make the car that much faster. What they are going to do is affect the driver. For example, I have a neuspeed front bar in my car because I didnt like the way the front end felt in hard corners. So on stock tires and wheels I could go faster because I was more confident in the front end feel. Did the mod make the car faster or just allow me to get more out of it? I have a RSX rear sway bar as well. This affected the ballence of the car to make it suit my preferance better. If you were to examine the actual performance numbers, I'm sure it didnt do much but I am much happier with its behavior durring corners. what I'm getting at is that these simple mods are good ones because they have dramatic effects on the way the car drives, and those changes are ones that most people like.
Old Aug 10, 2004
Zzyzx's Avatar
Autocross Junky
^^ he brings up an interesting point..
let me throw another at you guys.... would you rather add a part that makes the car Feel better , or one that actually makes the car handle better??
Old Aug 10, 2004
robbclark1's Avatar
Retired suspension supermod.
Define feel? If you mean feel better in terms of the driver being able to understand the car's motions, then I would have to say both. Example: my car feels like **** when hitting bumps because of the high spring rates, but I also know that it "feels" better than stock. It allows me to make quick responses more accurately and safer. Does it handle as well as I would like it? No, but I definitely feel safer in it.
Handling is all relative. I think if a driver can feel out his/her car and be able to drive it safely through rain, snow, sleet, quick responses, then the car "feels" right to them whether or not it handles like an autox/road racing car.
Old Aug 10, 2004
Zzyzx's Avatar
Autocross Junky
exactly, how you want your car to Feel or handle like is your choice... and if a part makes the car feel better to you, no matter if it actually effects the handling of the car much, then its a good part for you.
The one concern I have with people modifying their suspension is this... Basically there are 2 paths you can take when modding the suspeinson for performance... the street driven path and the ***** out autocross/race track path.
the street driven path is by far the safest of the two, and I'd suspect would be more then adiquite for the majority of people who want better handling on the street, even posibly with limited track use. Esentially you go out and buy a set of sport springs and some shocks (Often forgotten) or maybe one of the cheeper "Coilover kits" then you get what ever wheel and tire combo you want, a few chassis reinforcements, and finally you upgrade the anti-roll bars, probably with bigger bars both front and rear. what this does is crate a car that will handle MUCH better then stock and sure as hell Feels much better then stock. Will it make the car handle as well as it could?? Most likely not, but it will probably handle well enough to satisfiy the average joe driver, and still keep them Fairly safe. As in, the car will mostlikely understeer in most "at the limit" situations, wich is good. It keeps you from getting in to too much trouble.
Then there's the autocross/track setup.... Typically a well preped autocross (assuming your not running the stock classes) or road course car will be fairly unstable on the street. This does not mean that it is undriveable on the street, but rather you have to be more aware of how you are driving. Simply because the car will be more apt to punish you for your driving mistakes... as in, you will be more likely to spin the car when you mess something up then with a more understeer tuned car... How you set it up vaires, so I wont get in to it.
what does this mean?? Personally, i'd rather see someone tune their car to the Street side, They will be more then happy with the handling and it will keep them and their pasengers safe.
This is coming form an Avid autocrosser who went from an understeering pig of a car, to a Fully Preped nationaly compeditive car (89Si)... All that I can say is the si can do things on course that my car can't even dream of doing, but I wouldnt want my mom to pick up groceries with it... (now that I'm not driving that si, I've put alot of effort in to making my 01 EX handle as close to that car as possible... which explains my Anti-roll bar selection... )
Old Aug 10, 2004
trance4mer's Avatar
^^^^interesting. im looking to really gettin into auto X and road racing. but my car will be driven to skool and to werk everyday as well.... what u recommend??
Old Aug 10, 2004
Zzyzx's Avatar
Autocross Junky
Eh, Run how it sits now, preferably in the Stock classes.... That will teach you more then any thing.
if you must modify then wheels and tires will make the single greates improvement in handing. (save for some light 15X7s) after that, springs and shocks.... either Konis with ground contorols (or other adjustible spring) or one of the higher end "coilovers".
then, Drive the car some more..... learn its new limits..... then you can start lookingin to anti-roll bars. and hopefully by then you'll know more of what you want to tune the car to do, so you can pick out the right anti-rol bar... or bars.
also the proper alignment can make the difference between an understeering pig of a car and a well handling car.
Basically, I'd have to say get as much seat time as you can, change only one part at a time, and above all Spend time tuning You as a driver... Not all handling problems are because of the car.
Old Aug 17, 2004
HondaLuver's Avatar
yea... i dont' know what else to do with my suspention... short of a roll cage... but i love the handeling with this... the only think i think i can do is get better tires...
i gotz
Neuspeed front polished Strut bar
Neuspeed "X" brace
Cusco rear upper Strut bar
Tein SS dampers
SPC camber kit front and rear
Grey's custom endlinks
Progress front sway bar
Progress rear sway/tie bar
Centerline rpm's 18's polished (14.5 pounds)
Parada spec 2 215/40/18
Rear disc brakes off a 02' Si
Old Aug 17, 2004
robbclark1's Avatar
poly bushings all the way around.
Old Aug 17, 2004
dj02's Avatar
**** can thoes rims, and tires and get some 15's or 16's with some sticky tires.
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
speedlever
Sep 24, 2015 07:18 PM
