JIC Bar (56k Warn)
Search and Learn
JIC Bar (56k Warn)
JIC bar for DC5.
End Plate
Didn't provide replacement bolts for the bar.
So I went out and bought new washers and bolts from local hardware Store.
Comparsion.
Test Fit.
During Installtion.
Freaking bolt snapped in half.
:yellm: :yellm: :yellm:
Bar is not installed because of that snapped bolt.
Possibly it was a message from god saying I shouldnt add unnecessary weight to my car.
:angel:
End Plate
Comparsion.
Test Fit.
During Installtion.
:angel: Last edited by civicvtec1ps; May 7, 2004 at 08:51 PM.
Aight man, don't fret it... just get a 1/8" drill, make a pilot hole in the middle, then keep reaming it larger, eventually you'll get close enough to the edge that it'll give way and you'll spin the stub out the back (assuming the hole isn't blind), If its blind, then get as close to the outside as you can, then get a tap for that size hole and clean it out with the tap. You can fix that easily,
Search and Learn
Update.
Tried to fix with Drill Out tools.
Didn't work too well.
So I bought Self tapping screws and It's installed now.
I will post new pictures later tonight.
Search and Learn
Originally posted by Civryder02
wait wait ... will the cusco strut bar fit civic's ??
Boilermaker1 and couple other members has Cusco rear upper strut bar installed already.
Search and Learn
Originally posted by usafstud
can u close ur back seat yet???
read about ur post on HT
But I will try to come up with solution.
Originally posted by Green Civic
Nice. Feel a difference?
It's been raining for couple days.
Raiool
Oct 1, 2015 10:42 AM
beanhead
Sep 24, 2015 12:04 PM
