sway bars
Old Apr 22, 2004
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
sway bars
ok...so an '03 7thgen has a 16 mm front sway bar right?? does that just bolt right into a 2001? and how big is the front sway on an rsx?
Old Apr 22, 2004
robbclark1's Avatar
Retired suspension supermod.
yes it has a 16mm front sway bar. Yes it will fit a 2001, but unless you are racing there is no need to go from a 24.5mm (2001) to a 16mm (2003)front sway bar. the DX, VP and HX i don't think have any sway bars so you would need to mount those.
No you can't fit a RSX or Si front sway bar. The list of current aftermarket sway bars are in the FAQ which can be found in my signature.
Old Apr 23, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
i want the 01 ex front sway bar....damn 24.5mm is huge!
Old Apr 23, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
thicker front bar means more understeer at the limit.
Old Apr 23, 2004
dirtySAMURAI's Avatar
I log in from time to time
understeer sucks. my friend said that i had a little bit of oversteer now that i have my rsx rear sway in, but it still feels like its understeering.
i have a 2k1 meaning 24mm front and now 19mm rear.
Old Apr 24, 2004
I have a 2k2, 21mm or 22mm (forgot what is the exact #) up front and 19mm out back. I can make my car oversteer easily even before the limit. But mash the pedal understeer is still present.
Old Apr 26, 2004
Zzyzx's Avatar
Autocross Junky
Um.... mashing the Pedal in a turn = Throttle Induced Understeer = Driver Error, not car issue.
Ease off the gas, You'll take the corner better and accelerate out of it better.
Old Apr 26, 2004
HondaLuver's Avatar
Its a celebration bitches!
just play around with stuff, understeer sucks and too much over steer sucks, just see where you need what
Old Aug 2, 2004
trance4mer's Avatar
trance4mer is an unknown quantity at this point
how big is the SI rear sway bar??
Old Aug 2, 2004
Akutenshi's Avatar
The Rizing Sun
what size is the front and rear for a 2004 sedan?
Old Aug 2, 2004
Zzyzx's Avatar
Autocross Junky
trance4mer; the Si rear bar is 17mm
DrinkSoy; the two sedans that have anti-roll bars (LX and EX) the front one is 15.9mm the rear is 12mm
Old Aug 2, 2004
Akutenshi's Avatar
The Rizing Sun
i have an anti-roll bar on my 2004 lx sedan? waht the heck. ahahhaha i didnt know that. WHERE?! btw thanks for the info
Old Aug 3, 2004
Leets's Avatar
Leets is an unknown quantity at this point
I did... took all of 15 minutes.
Old Aug 3, 2004
civicvtec1ps's Avatar
Search and Learn
02-03 = 15mm
04 = 17mm
Old Aug 3, 2004
trance4mer's Avatar
Originally Posted by civicvtec1ps
02-03 = 15mm
04 = 17mm
thnx..
Old Aug 3, 2004
robbclark1's Avatar
You are telling me you put a FRONT sway bar on your 7thgen civic? Please explain.
Old Aug 4, 2004
Leets's Avatar
Yes, I put the front sway bar off of an '02 RSX (it was a type-s, not that it matters) onto my 04 LX. I just crawled underneath (didn't even need a jack thanks to the stock off-road suspension) and unbolted the stock sway bar. I was able to get it off without removing the exhaust by simply turning it as I pulled it out. I did the opposite with the 23mm bar, and it fits perfectly.
Old Aug 4, 2004
Zzyzx's Avatar
Autocross Junky
Did you do any thing to your rear bar? Because going from a 15.9mm to a 23 mm bar is going to cause some serious underster....
Old Aug 4, 2004
robbclark1's Avatar
hmm interesting...I always thought the front sways from the Si and RSX were different because of the placement of the cat. Maybe they will fit the DX/LX though. hmmmm
Old Aug 4, 2004
izmaxx's Avatar
izmaxx is just really niceizmaxx is just really niceizmaxx is just really niceizmaxx is just really niceizmaxx is just really nice
robb be baffled, hah!
Old Aug 4, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
If that bar would fit anything, it would fit the LX because there's no cat in the way. Still is interesting. You HAVE to move the exhaust on the EX BTW.
Old Aug 5, 2004
Leets's Avatar
I changed the rear bar to the 19mm RSX as well. There was an immediately noticeable increase in understeer, but the handling is vastly improved. I haven't driven a 01-02 with the bigger front bar so I really don't have anything to compare it to. All I can say is that the 04's a whole lot more fun to drive with the bigger bars.
The fact that the LX has the cat on the manifold makes the install and fitment completely trouble free. The miniscule exhaust pipe is only a minor inconvience.
Old Aug 5, 2004
Leets's Avatar
seriously... I never thought I'd be the one to stump him... I fell quite priviledged.
Old Aug 5, 2004
Zzyzx's Avatar
Autocross Junky
???? How can you say that handling has improved when you also say that you've gotten more understeer???
That would imply that the cars handling has actually gotten worse....
Old Aug 5, 2004
Leets's Avatar
The handling has improved because body roll isn't as evident. Due to the decrease in body roll the tires tend to hold the road better which provides the improved traction through a turn. As for the understeer, it allows for more control over the line of travel at higher speeds. I'm not sure how it was with the previous set-up, but on the 04s there wasn't much, if any, understeer to begin with. I found at high speeds it would often oversteer with the stock stabilizer bars. Therefore, I stand by my previous statement.
Old Aug 5, 2004
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
w00t i got a 16mm and gonna have a 19mm rear from a rsx type -s
Old Aug 5, 2004
shane's Avatar
shane is an unknown quantity at this point
I have an EX and an RSX front bar will not fit, but I checked it compared to an LX bend and it looks like it will fit an LX.
Old Aug 5, 2004
shane's Avatar
Posted this some time back:
http://www.7thgencivic.com/forums/sh...d.php?t=159419
Old Aug 5, 2004
Zzyzx's Avatar
Autocross Junky
#1. Body roll means very little in the way of handling... it only really does 2 things. 1, Annoys the driver and 2 causes a bit of camber loss in the corners. Thast it. So, body roll or the lack there of does not imply a well or poorly handling car.
#2. all Understeer does is force you to go slower through the corners. Simply because it causes a car to continue going in a straight line, if you approach the cars limits. Of the 3 states a car can be in durring a turn, understeer is the safest. In regards to handling, it is THE WORST state the car can be in. (A well handling car is inherently unstable). For better handling, a car should be nutural or slightly oversteer at its limits.
So, you havent made the car handle better, youve simply made it more stable and thus more user friendly.
I can pretty much gaurentee you that if you were to test back to back on a road course between the 15.9mm/19mm combo Vs teh 25.4mm/19mm combo, your lap times would be much better with the 15.9/19..... The car would feel more unstable, but it would be handling much better.
Old Aug 5, 2004
shane's Avatar
I ran the 15.9/19 then moved to the 25.4/19 as well, the car is much more balanced and in high speed cornering you can go much faster without audible loss of traction where at similar speeds with the 15.9/19 the rear tires are reaching their traction limits making quite a bit of noise. On an autocross course I would agree the 15.9/19 would probably be faster and throwing the rear end around out there works to your advantage and as long as you are on the accelerator you can keep it under control, its not exactly the same at road course or highway speed.
