Spring Rates
Old Mar 29, 2004
RedEU's Avatar
RedEU is an unknown quantity at this point
Spring Rates
Hey,
I just have a question, I'm currently searching for springs & shocks, & with all the different spring rates that area round, from neuspeed to eibach to tein, all varies tremendously. how do you know which would provide an acceptable ride yet great for cornering?
I have a linear 240lbs/in up front & progressive 215-240lbs/in at the back on standard shocks. I'm planning to change both. reason being i found the front being a bit too hard. still i get similar body rolls compared to stock. oh, all on 205/45R17. thanks..
oh, what are the recommendations? I planned to get the konis yellow, is there a better choice? thanks again.
Old Mar 29, 2004
Zzyzx's Avatar
Autocross Junky
You could run slightly softer springs and then use the Anti Roll bars to tune your handling.
also about springs, Non-Progressive springs are what you want for racing, Progressive springs were designed for the street for better comfort but still retaingin performance. Unfortunatly The Variable spring rate just messes with you when your racing (Road race/autocross) and make the car a bit harder to predict.
also, it may be your wheel/tire choice thats making the front end seem to stiff. Low profile tires arn't known for their impact absorbtion.
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
