Neuspeed upper strut bar help
I recently purchased a Neuspeed upper strut bar off someone, but he only gave me the bar, no instructions or anything. I read a couple of threads and some say I have to jack up my car, but why?
I think I can figure out how to install it, but if anyone can post instructions, tips, warnings or anything about installing the bar I would appreciate it.
BTW I drive a 5 speed Si Canadian (EX in US I think) and I have goldlines springs in case you are wondering. Thanks
You are going to take off the outer two nuts from the two strut towers with a 14mm socket. Then on the passenger side put the strut bar on the bolts, and then on the drivers side. If the drivers side does not line up with the holes you need to jack up the drivers side untill the bolts line up. Then screw the nuts back on with 30 ft/lb of torque. Have fun.
Took me at least a half hour to get the bar on. No jacking up the car though. I just put one side in a little and used a hammer to gently tap the other side into place. Then the whole thing just fell into the holes. Don't expect to get it on in 5 mins like everyone says.
It took me 5 min
. No jacking the car up, didn't relocated the clutch resevoir, just moved it out of the way.
. No jacking the car up, didn't relocated the clutch resevoir, just moved it out of the way. Search and Learn
You dont have to jack up your car to put front strut bar.
Took more than 5 minutes to do.
Anyways installation is really easy. Hammer will do it
33Ft/lbs actually.
about what i got mine in ...
ya i didnt have the manual anymore, i knew it was something close to 30
33Ft/lbs actually.
33Ft/lbs actually.
Thanks a lot guys, I should be able to do it now. I will try the soft hammering method first, if it doesn't work I will have to jack up the car. About the reservoir, I will think of something when I pop up the hood.
Ricerus Maximus
Originally posted by clownprince
For the resoivoir, there is another hole about an inch down that the bracket holding it can be screwed into. It requires some slight bending of the bracket but doensn't affect performance.
. I am so pissed off right now
. I tried spraying DW-40 and still doesn't work. I will probably ask a friend see if he can untighten it. Any suggestion guys?
didnt you use sockets to start off with? how did you damage the bolt?? it shouldnt of damaged it if you used a socket set?
maybe find someone with a drill set.. the machines that uses sockets.. im not sure of the exact terms
...like how a body shop uses that tool to untighten the bolts on the tires...
you can get that at wal-mart or canadian tire.
..or just return yout mastercraft extract-it kit.. and go to a shop and have them install it for 10 or 20bucks.... it will take them 5 mins. tops.
it's not worth it.. but they may have the tools to get your damaged bolt off. and whille they're at it, might as well install the strut bar and they may even have a brand new bolt lying around......
hope that helps.
hope that helps.
hope that helps.
hope that helps.
I did buy a deep socket after a couple of tries, but it still doesn't work, I am guessing because is damaged now.Everytime I tried to untighten it I could get a good grip of the nut, but after applying a lot of force the socket would just turn around the nut. I
know the machine you are talking about, and yes I have been thinking of taking the car to the garage but only after one more attempt (yes, I am THAT stubborn). I am proably keeping the socket kit thing tho, it might become useful. Thanks for the suggestion
i mean if ur trying to get a 14mm bolt off, u shouldnt use anything else but a 14mm socket.
ic
it could be the pressure of the weight going down.... but i highly doubt it.
jack up your car... it may release some of the pressure.
but when i think of it.. the pressure is going down.. not up, b/c it's a bolt on top.
jack up your car to give it a try... maybe honda did something that ew dont know... o_O
ic
ic
But now there is another problem. I asked around and nobody carries that nut. I tried Canadian Tire, Lorco and Napa so far. The guy at Napa told me that a normal hex nut, a washer and a lock washer would do. Right now I replaced the damaged nut with another nut, washer and lock washer, but I think I will check the honda dealer for the exact nut, because I fear it will become a problem in the future. Damn it, I just wanna install a strut bar and all this **** comes out
Yeah I ordered two from Honda, costed me $8 something total. Hopefull I can finally install the stupid bar after 5 days of trying. Thanks a lot for your input AznSaint.
