help me
Old Jan 17, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
help me
i got B&G full dropped... but the body sway wehn taking curves at 60 causes from fenders to rub a bit... rear's fine juist front and it only rubs on 90degree turns at like 60-70 what can i do to stiffen car and redice body roll...
im guesin ur gonna say strut bar, but what else can i do to front end.. i dont care about rear its so nice and stiff. whats with the RSX sways what do they do...
riley
Old Jan 17, 2004
HondaLuver's Avatar
Its a celebration bitches!
if you get a upgraded front sway, that will really help on ur car not rubbing...
there are alsorts of sway bar out there
Old Jan 17, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
how much,where, what kind....?
riley
Old Jan 17, 2004
Zzyzx's Avatar
Autocross Junky
90degree turns at like 60-70.... Sure.
Um, well one problem is that you may have the car to low. (for performance there is such a thing)
strut bar on the front will do nothing to reduce body roll, adding a larger front anti roll bar will make the body roll less and possibly stop you from rubbing up front, but it will make you understeer more.
other wise, if you want the car to be that low, and you dont want to rub, you'll need to get Higher spring rates.
Old Jan 18, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
yeah i got high spring rates and extra stiff shocks. and yes i do take em fast.... im crazy...hehe. love them turns on 19's :-D... maybe a anti roll bar.. where do i buy one tho?
Old Jan 18, 2004
Zzyzx's Avatar
Autocross Junky
well your rubbing now, so the B&Gs obviously dont have a high enough spring rate for what your doing with the car. and shocks dont reduce body roll.
If you do get a larger front anti-roll bar... well that may stop you from rubbing in a turn but its going to screw your handling.... Tons-O-Understeer. so if you do that, make sure you get a larger rear bar to balance it out.
