Bump Stops
Old Dec 29, 2003
02civic's Avatar
Need....More....Mods
02civic is an unknown quantity at this point
Lightbulb Bump Stops
is there something i can buy or rather manufacturer myself to use as a bump stop for the rear suspension. Ideally i'd like something i could just pop-in the springs to lessen their compression to keep more pressure on the front tires during launch. It would purely be for the passes on the drag strip. Would plain old pieces of rubber shapped around the strut do the trick?? or could this cause some sort of damage?
Old Dec 29, 2003
clownprince's Avatar
Ricerus Maximus
Look for coil spring stabilizers at Auto Zone. They will pretty much just sit in between the coils of the spring and stabilize it. Those should work for a few passes down the strip and when you are done just take them out.
Old Dec 30, 2003
02civic's Avatar
coil spring stabilizers eh....ok..i'll have a look around. Thanks
BTW..what are the intended use of these stabilizers? My car is lowered anyways...so my suspension sagging on launch isnt a major problem, just something i thought of while trying to figure out how to get my 60' times down.
Thanks
Old Dec 30, 2003
VNlilMAN's Avatar
The Standard One
what springs do you have?
Old Dec 31, 2003
Ricerus Maximus
The purpose of the stabilizers is to help older springs do their job. Old worn out springs sag some and these help to stiffen them up. Think box chevy old
SimpleUser
Apr 24, 2021 02:54 AM
mrohitredd
40
Sep 9, 2017 12:03 PM
DerbyDad03
Jul 27, 2015 11:34 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
mokkush
Jul 14, 2015 04:05 PM
