droopping car syndrome?????
Old Dec 13, 2003
navyedoc's Avatar
navyedoc is an unknown quantity at this point
i lowered my vic like 4 inches! now the thing sits slanted by a inch to the left..... does anyone have a clue why????
Old Dec 13, 2003
Mr.Modify's Avatar
what do you mean? one side of the car is lower than the other? if so what are you using springs or coilovers? what's your setup?
Old Dec 13, 2003
civicvtec1ps's Avatar
Search and Learn
Re adjust height . I assume you have coilover setup. Your stock shocks might be blown. Tell us what kind suspension setup you have.
Old Dec 14, 2003
navyedoc's Avatar
i have goldline springs cut to a 3 inch drop. stock shock struts. honda seems to think i need to cut the bumpers in half????? why does stupid **** happen to my baby????????
Old Dec 14, 2003
navyedoc's Avatar
and yes the left side sits maybe a >inch lower than the right
Old Dec 14, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
either you cut your spring uneven or your shocks blown, u need new shocks anyways, 3" is just too low, im suprise u can drive at all with one side 4" lower
Old Dec 14, 2003
navyedoc's Avatar
well see it did the same thing when i had 2 inch goldlines on it. the shocks dont seem blown though. it doesnt bottm out or anything. when i push down on all four, i get the same response. please help me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 14, 2003
robbclark1's Avatar
Retired suspension supermod.
even if you cut the bumpstops, i have a feeling your car will never drive right. You lowered 4 inches!!! that is way too much and you are still on stock shocks. Your car won't be happy with you. You must have messed up cutting the springs. I really suggest just getting a new set or if you want to lower 4 inches get air bags. Cars are NOT supposed to be able to be lowered that low and still be able to drive correctly.
Old Dec 14, 2003
HondaLuver's Avatar
Its a celebration bitches!
who did it?
and anything lower than 3 inches shouldn't be driven, unless it is a truck
Old Dec 14, 2003
guamcivic2k1's Avatar
YoUnG N SuXsExFul
wow that's a little too low for driving
Old Dec 14, 2003
navyedoc's Avatar
ok ok i know it was bad. its only supposed to be a 3 inch drop. but it is a little lower. and the car still drives fine. the only problem i am having is the left side sits lower than the right. BUT the same thing happened when i just had 2 inch goldlines???? whats up with that.......
Old Dec 14, 2003
HondaLuver's Avatar
Originally posted by HondaLuver
who did it?
please answer the question
Old Dec 15, 2003
navyedoc's Avatar
a shop cut them, then i put them on. y?
Old Dec 16, 2003
navyedoc's Avatar
vic is at honda getting evaluated, i will let you all know.
Old Dec 16, 2003
sspem2's Avatar
em2
invest in some B+G true coilovers if u want a low drop. im dropped 3 inches. my side skirts are only like 2.8 inches off the grund and my exhaust is like 1 inch off the ground. scrapin all day baby. hehehehhe
Old Dec 16, 2003
navyedoc's Avatar
yah me to. but i probably have a stiffer ride than you.
Old Dec 16, 2003
sspem2's Avatar
em2
the B+G's are very stiff. the ride is very smooth. your head isnt gonna go flyin if you just hit a lil pot hole. very nice ride. i recommended B+g's
Old Dec 16, 2003
navyedoc's Avatar
cool thanks. i really want to keep my goldlines though. maybe when i finish my swap (whenever that is) i will swith to them.
Old Dec 16, 2003
HondaLuver's Avatar
u should take it back to the shop... if they messed up ur car they should fit it, if they didn't mess it up, take it to a professional.
Old Dec 16, 2003
navyedoc's Avatar
honda says the springs are colapsed...... coilovers anyone?????
Old Dec 16, 2003
HondaLuver's Avatar
just go and get some dampers if you want anything that low. like b&G
Old Dec 16, 2003
TommyC225's Avatar
TommyC225 is an unknown quantity at this point
wat do u mean the springs are colapsed!
i dont understand please explain?
and how does one become colapsed or is it just a defected one?
Old Dec 16, 2003
navyedoc's Avatar
probably defective. see, they were just a 2 inch drop untill they were cut. Colapsed meaning they cannot support the weight of the car
Old Dec 16, 2003
Search and Learn
Well duh, You pretty much fooked up springs rates when you cut those springs. Drop it property. Why would you even want to drop your car that low? Save up and buy fullcoilovers. Or just get sleeved coilovers and drop it. Not freaking 4 "!!
Old Dec 17, 2003
navyedoc's Avatar
thanks man, i bought coil overs yesterday
Old Dec 18, 2003
navyedoc's Avatar
coil overs will be here in 6 days. i will let everyone know how it turns out.
Old Dec 18, 2003
sspem2's Avatar
em2
what brand
Old Dec 18, 2003
Search and Learn
Originally posted by 1siksivik
what brand
Probably Aerospeed lol.
Old Dec 18, 2003
navyedoc's Avatar
very funny, i think they are ground controls?? red and gold i one perch?
Old Dec 19, 2003
navyedoc's Avatar
bump
