heyyy someone help me! lowering
Old Dec 8, 2003
wogz's Avatar
wogz is an unknown quantity at this point
hey okay, i installed neuspeed race springs and ingalls camber kit. that was on sunday, and my fender gaps are different, on all sides. like my front right is lower then my front left, and my rear left is lower then my rear right.. the people who installed it said it was cuz i need alignment, he said he hadnt installed a camber kit on our civics so he adjusted it all the way or something and the tires are really croooked, so is all i need to get is alignment, i doubt that they installed it wrong because they do realy really good work, so do i have a problem or do i just need alignment? i went to get alignment today and they said my car was too low to get on the ramp!
Old Dec 8, 2003
civicvtec1ps's Avatar
Search and Learn
Recorrect camber kit again. Let spring settled. Just drive around for while. And have fun finding shops that will do alignment for lowered cars.
Old Dec 8, 2003
wogz's Avatar
hey, any other opinions!!?? iwent to NTB today and they said my car was too low to align! what shall i do
Old Dec 8, 2003
Vinh's Avatar
shoulda bought some teins
Old Dec 8, 2003
wogz's Avatar
um okay, what for? i want my car low...
Old Dec 8, 2003
4bangin's Avatar
ya ntb is like the only place that will do it and my car on goldlines is almost too low.
Old Dec 9, 2003
VNlilMAN's Avatar
The Standard One
just wait for it to settle. give it like a week. as for alignment, you shouldnt even get it now anyways. but ya not too many places do alignments on lowered cars so good luck finding a place...
Old Dec 9, 2003
wogz's Avatar
why shouldn't i get alignment? my tires are really slanted
Old Dec 9, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
honda dealerships will do it.. but it will run around $150 due to altered suspension.. i did my own... hehehe... but anyways... go there.. and beg for the oldest tech they have... they do it best... honda WILL do it for the right money,,, TRUST me
Old Dec 9, 2003
tfnaaf's Avatar
BLDNPSI Mod
One issue alot of alighment shops have with lowered cars is the alignment machine usually needs to see across the front of the car. With a lowered civic, it mostlikely wont unless you remove the front bumper specially if it has a body kit on it. Offer to the alignment shops to pull the front bumper its only like 2 mins or so to pop it off. This may help on getting a shop to align it. Some shops that have the newer alignment machines that use cameras to align the car dont require to see from one front tire to the other. So the bumper wont be an issue on those
As far as NOT aligning it till it settles???????????? Procedure for installing lowering kit after you get the tires back on go directly to an alignment machine do not pass go, do not collect $200 If you can SEE the camber in the tire ( slanted ) then it MUST be aligned if for no other reason than safety.
As far as the different ride height?????? sounds to me like they didnt get the springs seated in the proper locations on the struts or something. I suppose that if the camber is off enough it could make it look higher or lower on one corner over another. Some shops will offer free alignment checks , specially if you paid to have it aligned at their shop. If by some odd reason the springs were to sag in the first month or so would be do to CHEAP springs! My springs on mine are close to 2 plus years old and only sag ive gotten from them is from the added stereo equipment
I would suggest calling around to find a alignment shop that has a pit rack. this will or should overcome the not being able to get on the rack part. Next would be to have them check the supension to insure its not #$%@'d up from the install.
One last thing to consider is after the alignment is done check your tires for unusual wear patterns. Just cause they SAY its algined dont mean its set for proper tire wear. A good alignment tech can usually judge how much its lowered and the size of tire and adjust from factory spec from there. I would fist suggest to get the alginement set within factory tolerances. then have it adjusted to how the tire wears if that makes any sense? If you cant seem to find a good alignment tech, or one that has dealt with lowered cars the main angle of concern assuming they get camber to with in tolerances is "TOE"! I forget what the exzact spec for toe on the civics is but if your running wider tires you will want to set the initial toe setting to be somewhere between spec and max spec toe IN. Because the Wider tire will try to somewhat force the tire out as you drive down the road
Old Dec 9, 2003
tfnaaf's Avatar
BLDNPSI Mod
BTW, I've done an Alignment or 2 in my day
Old Dec 9, 2003
VNlilMAN's Avatar
The Standard One
hmm... alright lets get an alignment right after i get my car drop. then lets wait another week so that my car drops another inch and get another alignment... really smart... getting an alignment is important but not that important... negative camber? safety? uh... having -2 degree camber in the rear isnt really going to be dangerous. it'll even give you better control for your turns...
but ya reason why i say wait a bit before you get an alignment is cause springs take some time to settle. usually its very noticeable within 3 days but i would wait a week.
Old Dec 9, 2003
tfnaaf's Avatar
BLDNPSI Mod
guess you've had your eye calibrated recently? say neagtive 2 degrees on right side and pos 1 degree left side. Not a safety issue huh ? If you dont think so then youhave no idea what your talking about. and if your springs settle an inch in one week. you got some pretty crappy springs. If your springs are settling an inch in one week, how much do they settle in one year?
Old Dec 9, 2003
VNlilMAN's Avatar
The Standard One
right after you lower your car, check how high it is... its basically stock height... your going to get your car aligned then? a week without getting an alignment isnt going to kill you.
and especially since his car isnt even sitting straight... i dunno this should say that somethings wrong here... most likely the springs arent settled in fully.
Old Dec 9, 2003
wogz's Avatar
actually the car is really low after a day, far from stock.... people say that its going to lower another inch, but theres already like only 1 finger gap for the front fender, so i doubtt hat!!!
Old Dec 9, 2003
VNlilMAN's Avatar
The Standard One
eh i have no finger gap but then again i'm running 215-40-18s... what are you running? ya the settling is very noticeable within the first 3 days. thats why i say wait a week before getting an alignment... but then tfnaaf disagree's so
Old Dec 9, 2003
dj02's Avatar
camber kit alignment???. wtf are these things????
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
bhollie
Sep 22, 2015 11:08 PM
