My ride quality sucks with new wheels/tires
Old Dec 1, 2003
ccajun4real's Avatar
ccajun4real is an unknown quantity at this point
Exclamation My ride quality sucks with new wheels/tires
I just went from stock to 18's with 215/40-18 Hankook Ventus K104 tires. My ride quality has gone to ****. I can feel every little bump in the road and the tires seem to really catch in grooves in the road and roll me around.
I am about to install a set of Neuspeed sport springs, is this going to make my ride quality even worse? Damn I dont know if I can sacrifice the looks for the degredation in handling.
Anyone else have this problem when switching wheels?
Anyone have the Neuspeed sports and notice a difference after install either good or bad? Thanks
Old Dec 1, 2003
civicvtec1ps's Avatar
Search and Learn
Yea i am sure ride quality sucks with 18" wheels. Ride will get alot worse with lowring springs. You will feel every little bump in the road. I am not sure about those tires but maybe upgrade with new tires eventually. 17"(215/45/17) was perfect for daily drive for me. Even with drop. Rides pretty good. Cant complain. If you are really tired of having crappy ride. Just sell those and buy smaller wheels.
Old Dec 1, 2003
Zzyzx's Avatar
Autocross Junky
Your on 18's of coures your goin to feel every bump in the road you have about an inch of tire between the road and the wheel......
Old Dec 1, 2003
So do you think it can harm the car or the wheels? I want to make sure I dont mess something up? Thanks
Old Dec 1, 2003
What can I do to make it ride better? New shocks? Coilovers?
Old Dec 1, 2003
Zzyzx's Avatar
Autocross Junky
well to not damage the wheels you are going to be carefull to avoid potholes and other such road hazards. the neuspeed sport springs are going to make you feel the road even more.
If you want to keep the 18 and have a smoother ride, then you're going to need some springs with lower rates, and a set of Softer shocks.
the issue you're dealing with on your car is 2 things, 1 is the lack of tire between you and the road and the other is the Higher unsprung weight that your suspension is having to deal with. with 18s on a civic there is a level of ride harseness that you are just going to have to live with. because, you can only put so thick of a tire on an 18 and still have it fit, and you can only go so low of a spring rate and not have the car bottom out all the time. a set of Koni might smoth it out a little, but Konis have stiffer valving then the stock shocks so you may actually feel more of the road (even on their softest setting).
Good luck with that, you may just have to learn to like it.
Old Dec 1, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
^ agreed to that
personally i don't believe u can get a smooth ride with 18's +
with softer shocks, and springs, u may even encounter more problems (like tire rubbing whenever u hit a bump or somethin) ... like zzyzx said, u'll just have to deal! >_<
Old Dec 2, 2003
HondaLuver's Avatar
Its a celebration bitches!
suck it up and be a man...
Old Dec 2, 2003
Sounds like something we would say in the airborne. By the way nice avatar............for a 12 year old
Old Dec 2, 2003
Civictuner04's Avatar
Civictuner04 is an unknown quantity at this point
Your problem is ur 18's. It is almost impossible to have a good ride quality with them. I have 17's (215/45/17) and they have greatly improved my ride and handling. I got Toyo Proxes FZ4's. Konis shocks, as mentioned above, will most likely not improve your ride. So, also said above, you can either live with it or sell them: your choice?
Old Dec 2, 2003
Well I guess I will have to put up with it and get used to it, just hope I dont bend a wheel..................that would suck
Old Dec 3, 2003
Yakkolio's Avatar
Yakkolio is an unknown quantity at this point
your ride will go to crap when you upgrade, thats just how it is because you have thinner tires that have to absorb more.
Old Dec 3, 2003
HondaLuver's Avatar
like i said above.... o yea with less tire, there is less tire flex, now you can hadle corners better
Old Dec 3, 2003
Allright man, you seem to be the resident expert here? What do I need to do to go ahead and stiffen this suspension up? Hell as long as I am going to ride on rims I midas well not have body sway and frame flex. I can get front STB lower tie and rear lower tie. Is there a good combination that works best on a Civic coupe? I cant find the rear STB on ebay and I am not willing to pay big bucks for it so that is not an option I guess..........unless I REALLY need it? Thanks to all................even you dude
Old Dec 5, 2003
Logan3024's Avatar
1. 40 series tires are not designed for comfort.
2. Hancocks are not the best tires. thoses tires are worse than kumhos. Very noisy tire also.(pep boys sells them)
3. 18's with stock springs means your car is going to be sitting higher than stock, extra body roll.
Lower your car and it wont handle like a truck.
Old Dec 5, 2003
I am puttin on Neuspeed sports on next week. Thanks bro
skeener51
Oct 1, 2015 05:56 PM
beanhead
Sep 24, 2015 12:04 PM
BBrosario
Sep 17, 2015 07:51 PM
