which is the best? Eibach,Goldline,Neuspeed or Tein
Old Nov 28, 2003
carbonrevo's Avatar
carbonrevo has a little shameless behaviour in the past
Here is my situation, I have a camber kit installed, not enough money to buy complete suspension kit, only have money for springs, I need to make my decision whether I should get Eibach, Goldline, Neuspeed or Tein, they are about the same price, I need to know which is the best for civic 02 EX coupe.
Also another question with right springs and camber kit, will there be a great chance I will blow out my struts ?? Thanks
Old Nov 28, 2003
Mr.Modify's Avatar
EIbach: 1 to 1 1/2inch
Goldline: 1.75inch all around
Neuspeed: i believe 1.50-1.75?
Tein: 1.25-1.50(not to sure)
but the point is how low do you want to go? Also you won't blow out the struts but most likely eventually the shocks might began to feel a little wear and eventually blow....that's why alot of people replace the shocks or get true coilovers which isn't a option for you but there really isn't a best but for "best" ride i'm going with EIBACH!!
Old Nov 28, 2003
C0rnfl4k3's Avatar
C0rnfl4k3 is an unknown quantity at this point
Eibach Sportlines on 17's
Old Nov 29, 2003
Braydogg's Avatar
Braydogg is an unknown quantity at this point
I heard pretty good things about eibachs.....!!!
Old Nov 29, 2003
robbclark1's Avatar
Retired suspension supermod.
Please read the FAQ in my sig. We can't sit here and tell you what is the BEST spring because it can't be done. Everyone likes different things. If you think that all those springs you mentioned are the same price, they aren't. Yes you will need a camber kit, and yes your shocks will most likely blow. Please READ everything you can about each brand. Use the search function above. We have talked about all these brands of springs already. If you don't know much about lowering, please read up on that through the FAQ and the Suspension Tuning 101 above. Thank you.
GolNat
Nov 27, 2018 03:32 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Viczhou
Sep 2, 2015 07:55 PM
