Need comment on full coil over kits
Old Nov 18, 2003
DragonZ's Avatar
DragonZ is an unknown quantity at this point
Cool Need comment on full coil over kits
i have a 01 ex coupe can i have a blown oem shocks with goldline spring and my car is getting worse everyday i wonder if i should just buy a full coilover kit or should i just get the konis...
and i saw in one of the thread over here about hayame or somethings does anybody got the report on it ....
Old Nov 18, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
i have the Tein Type Flex kit and uhhh yeh they are awsome i wouldnt go for the flex if u are strapped for cash though the ss is probably about just as good not as agressive though and no upper pillowball mounts....i would go with a full co rather than sleaves from past expierences
Old Nov 18, 2003
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
where's the best or cheapest place to get them?
Old Nov 19, 2003
i got my coilovers from tornactive.com he's a member here also
Old Nov 22, 2003
slowvic's Avatar
slowvic is an unknown quantity at this point
jdmb16ahatch: How is your handling w/ the ep3 type flex? I'm considering them for my coupe but am afraid the spring rates may not be right, since the ep3 is heavier.
Old Nov 24, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
coilovers are too sensitive if you change your ride height.
You practically need the wheeles aligned each time youchange the height
otherwise you will have uneven wear on your tires.
Also coilovers feel too stiff. go with the konis and get some progressive
rate springs...I chose H & R's ...no problems and they have been on 3 years now.
Old Nov 24, 2003
Zzyzx's Avatar
Autocross Junky
in the debate of Coil over Vs inserts it really depends on your budget and what you want out of your suspension.
Pro for Coilovers:
1. preassembled with matched spring rates (Rates may be higher then Stock so expect a Rougher ride).
2. Built in ride height adjustment.
3. Most have at least bump adjustment on the shock.
Pro for inserts (Konis)
1. Low cost
2. Konis (At least the Yellows) have adjustible Bump
3. Koni will happily re-valve their shocks to meet your needs (For a small Fee)
4. Most National level autocrosseres run on a set of Revalved Konis (Rather then a set of "True" coilovers. Why? because if properly done the konis give you just as good perfomance as a Coilover with out the cost.)
Con for Coilovers
1. Higher cost
Cons for Inserts
1. Lack of a matched spring rate (you have to do the work to find the best rate)
2. Possilbe issues with installation (Find the Absolute best shop for the job)
Personally, I have 2 options right now. either waite for the KW V3 to come out or get a set of Konis......... Im getting tired of waiting.
Old Nov 27, 2003
Blue_Honda_Civ's Avatar
I drive a jeep to compensate for my tiny pee pee
Blue_Honda_Civ will become famous soon enoughBlue_Honda_Civ will become famous soon enough
why not spend the extra 200 and get the tein flex worth everypenny
Old Nov 29, 2003
robbclark1's Avatar
Retired suspension supermod.
the Flex are a good set of coilovers. however if you aren't going to use them to their full potential then it is overkill. They will be really stiff. The tein SS or Basic will be fine for the everyday driver. The flex is more geared towards racers whether it be autox or road racing.
This is how i see it.
Custom valved Konis to handle more than 450 will cost ya probably around $650 or so. Plus you get custom rated springs that will cost ya aound $2-300 depending on the spring. So now you are at a grand or so just for Konis and springs and you don't even know if they are going to work well together. Now add in installation because Konis are not for the regular DIYer and a camber plate that costs $3-500. You are almost at the cost of full coilovers. Now if you had the money to test and tune spring rates with cutomed konis then be my guest, but for a simple swap out job, then full coils are the way to go. That is just my opinion though!
Old Dec 1, 2003
i wouldnt say its for everyone ive had the teins before in my 88 hatch for 3 years doesnt ride anywhere near as nice as the flex do but its strickly a track car now....i wouldnt say they're overkill but thats my opinion
Old Dec 1, 2003
PunkingCivic's Avatar
I need TP for my bunghole
KW suspension has a $200 rebate
http://www.kwsuspensions.com/news/may03/rebate.htm
zaboomafoozarg
May 30, 2015 09:21 AM
Bigdaddy198
Apr 30, 2015 08:36 PM
speed werx
Nov 27, 2001 08:52 AM
duyaknow
Nov 23, 2001 07:28 PM
Elusiv1
Nov 8, 2001 10:12 PM
