Poping of the Ground Control Coilovers
Old Sep 22, 2003
01RedHondaCivic's Avatar
01RedHondaCivic is an unknown quantity at this point
Question Poping of the Ground Control Coilovers
I have had my Ground Control Coilovers on my car for about a month now and i hear almost a poping sound when i turn my car. They say that it is just the coil Spining and that it will go away. Is this true and i still have the stock shock and struts in my car. Is there anything i can do to help not pop as much. Please need help getting aggrecated.
Old Sep 23, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
nope...i know exactly what you're going through...i've had my gc's for almost 6 months now, and it still pops every once in a while. Only way to prevent it is to lube the end of the springs, and drive less agressively. Everytime you hit a bump or some sort of road abnormality, there is a chance the spring will pop out of the groove, and when you drive around again, it will snap back into the groove and make that popping sound.
I dun think it will ever go away with time...i think getting new stiffer struts might do something
Old Sep 24, 2003
TOOLOWCIVIC's Avatar
I've had mine for more than 2 1/2 years and it did go away. Now I have a popping noise when I hit a bump coming from my drivers side. I dont know if its a Koni or what.
Old Sep 24, 2003
§C§H§O§C§O§B§O
probaly the koni's...dunno, i still run on stock struts...waitin for the tein flex ^_^
Old Sep 25, 2003
onebuddha1's Avatar
onebuddha1 is an unknown quantity at this point
i have skunk2 coil sleeves and when i turn my steering wheel... my springs "pop".... to my understanding .... and correct me if im wrong.... the top mount or the front suspention changed between tha 01 and tha 02...
when you by teins... for peeps with 02+.. you have to by the 01 bearin mount.... does that mean you need to buy these mount for other kits.. like ground control or skunk2 ?
Old Sep 28, 2003
DroppIN808's Avatar
DroppIN808 is an unknown quantity at this point
like what onebuddha1 said i think it is the upper bearing mount... i ordered 01 bearing mount for my tein coilvers havent installed them both yet. my accord used to make noises like that when i big *** bumps or rocky roads then pop back into position i guess.
GolNat
Jan 12, 2021 09:06 PM
JKWood
Jul 28, 2015 03:45 PM
EM_WON
Jul 22, 2015 06:49 PM
