Frustrated! Rear Lower Tie-Bar 3 hrs
Old Sep 2, 2003
integ108's Avatar
integ108 is on a distinguished road
okay so i just finished installing a rear lower tie bar on my civic 2dr and man it took 3 hrs from dissasemble to assembly. its not as easy as it looks i had to jack up the car, unbolt the dreaded lower control arm bolts (2) and everything goes fine up until i have to ALIGN BACK THE HOLES!!!! this is a very stressful and dreadful thing to do. it took about 4 hand jacks and some guys to tug the wheel in order to align up the holes. when i do finally get it in, what a payoff it is. looks like a beauty. the thing that pi$$ed me off the most was hondas engineering, the people who designed the lower control arm should be taken out and beaten, the bolt that holds the lower control arm only goes in by screwing the bolt in theres no nut to secure it, so now im going to be driving with the worry of the rear flying off in the back of my head.
good luck for those who are going to install rear lower tie bars!
has anyone else had a similar experience with aligning the holes for the lower contorl arm?
Does anyone know the torque specs of the rear lower control arm bolts?
Old Sep 2, 2003
robbclark1's Avatar
Retired suspension supermod.
You are supposed to brace the rear control arms so that doesn't happen. Usually people use a piece of wood so they don't move. Just tighten it until you can't anymore. No worries. If you are really worried, I think it is 80lbs, but don't quote me.
Old Sep 2, 2003
snoopbag's Avatar
snoopbag is an unknown quantity at this point
I just installed my Tenzo R rear lower the other day... easy as hell. One of my hole wasn't aligned but I just pryed it back up with a screw driver and presto!. There is also a nut welded on the backside of the control arm the the bolt screws into.
Old Sep 2, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
i agree really easy.. my car was on my friends lift (he works for bmw... and it lifts from the frame he had floor stands that held the arms in place... took us a whole 30 seconds.. with air tools.. lol
Old Sep 2, 2003
civicvtec1ps's Avatar
Search and Learn
very easy. took 15mins to install. just need to use block. and screw driver
Old Sep 3, 2003
integ108's Avatar
guess im just a f_ _ _ _in Du_ _ A _ _
Old Sep 3, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
LoL, happened to me before. Yeah, it sucks. It doesn't sound as bad as the front axle popping out when you remove the struts though, but you still gotta find the center and take your time with it.
Old Sep 3, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
lol thats not too bad.. that sucks yea but its cake to get them back in... just use alittle muscle and they go right back in lol
Old Sep 3, 2003
integ108's Avatar
i think its easier to perform a motor swap than put in a rear lower tie bar in, in my opinion
Old Sep 3, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Whats wrong with the Honda Engineering? Seems to me the bolt works just fine and dandy. They didn't design it to be removed so you could put a tie bar in. As far as they were concerned, it was designed strong enough for the loads that would be applied to it. If you're cranky about bad design, be cranky about who designed the bar that had to go there... or better yet, just deal with the fact that if you're gonna modify the car, you're gonna have to take it apart, and then figure out how to put it back together.
I did it with hand tools in about 1 hour. All you had to do was run another bolt or a screwdriver in from the back side as you pulled the bolt out... it would have stayed in place.
Old Sep 3, 2003
Grey's Avatar
DIY King
DC Sports tie bar instructions said something like 43 foot pounds. I think that's what I used...
Anyway, I had the same problem. Those damned control arms slip out of their sockets and they're a bitch to put back on. Taking off the wheels helps a little. As does taking off the upper control arm. That's what's pushing the control arms out...
Old Sep 3, 2003
All Eyes On Z
We have a guy doing a DIY engine swap with a K20A2.
He's been at it for over 1/2 a year.
The difficulty of wiring up the new engine is 10-fold... and even more, compared to a tie bar installation.
Old Sep 5, 2003
tamazoid's Avatar
tamazoid is an unknown quantity at this point
after u guys installed the tie bar, did u guys feel the car riding smoother? as in it feels softer? but at the same time, the car feels pretty tight on turns? hope u guys understand what i'm trying to say...
Old Sep 5, 2003
Drnknmnky13's Avatar
I installed it in about 30 mins. It certainly wasn't rocket science. Block of wood to keep it in place and a screwdriver in the hole. As far as feeling a difference? NO. A roll bar yes...but just a tie bar? I think the butt accelerometer is playing tricks on you.
Old Sep 5, 2003
ITDawwg2001's Avatar
ITDawwg2001 is an unknown quantity at this point
I know what you mean about being frustrated about installing the tie bar. I am a newbie myself, and it took my friend and I about 30 to 45 minutes to install the DC Sports lower tie bar. The most time consuming part was--you guessed it--realigning so that the screws would fit back and could be screwed back in.
However, I am still having a problem with it. Is there anyone that has any tips for me on making the installation more even? My right (passenger) side is slightly higher than the left (driver) side. How can I even this out? Please respond. Thanks.
Old Sep 5, 2003
integ108's Avatar
what do you mean the passenger side is higher? the tie bar or the height of the car? does anyone know what the racing lower control arms do?
Old Sep 5, 2003
I was refering to the tie bar. Sorry for being so vauge.
ITDawwg2001
JohnnyBxo
Nov 12, 2015 03:04 PM
cukaracha
30
Jul 26, 2015 12:01 PM
Nalmonte
Jul 22, 2015 09:08 AM
OptimisticWay
Jul 10, 2015 04:31 PM
SpecialRequest
Jul 7, 2015 07:52 PM
