aftermarket springs w/ 19s?
Old Aug 28, 2003
PeN8503's Avatar
PeN8503 is an unknown quantity at this point
first off, i dont know where to post this so i posted it both in wheels/suspension categories since it involves both...
If i got 19s, what tires would i need, and also, would i need some stiff aftermarket springs? cuz i find the stock 7th gen civic springs very bouncy.......any ideas? or suggestions?
Old Aug 28, 2003
civicvtec1ps's Avatar
Search and Learn
i would go with 215/35/19 and fullcoilover setup.
Old Aug 28, 2003
sspem2's Avatar
em2
215-35-19 with goldines 1.75 drop here
Old Aug 28, 2003
VNlilMAN's Avatar
The Standard One
hey whussup you from LA? should check out the socal section. we have meets every now n then.
215-35-19s are a must. nothing bigger. and ya you should be able to get away with a 1.75" drop. thats anything from neuspeed sports to goldlines to eibach sportlines. you dont NEED aftermarket springs but highly recommended cause you'll look like your 4x4'in
Old Aug 28, 2003
PeN8503's Avatar
ok cool yea i live in LA---Louisiana not los angelos. sry
coilovers?? or springs?? also do i need camber kit??
Old Aug 28, 2003
Search and Learn
coilovers?? or springs?? also do i need camber ??
http://www.7thgencivic.com/modules.p...Suspension+FAQ
read this
Old Aug 29, 2003
VNlilMAN's Avatar
The Standard One
i wouldnt recommended sleeved coilovers cause all those are going to do are blow your shocks. if you can and want to, i would recommend you get true coilovers. they run from $900-$1200.
if not lowering springs are just fine. i would personally get neuspeed sports. there's a chance of it rubbing but theres always ways to fix it. camber kit is recommended for anything lower than 1.75"
Old Aug 30, 2003
Snort2001's Avatar
Snort2001 is an unknown quantity at this point
are those the same rims that blackbullet has? Racing Hart C5s?? and yea, i was playing with the tire calculator...and for the EX, it seems as if 225/30/19 would be a better match, but the tire wall is so much smaller that your rims may get bent easier. plus, i don think 225 tires can fit under our fender cuz i already had problems fitting a 215. had to shave the inside of the fender to fit them.
Old Aug 30, 2003
PeN8503's Avatar
send a link for the tire calculator please
Old Aug 30, 2003
PeN8503's Avatar
also, snort2001 ur civic is hot, those w7s look sweet. plus i hear they cost like 1grand per sub...thats crazy and must sound fantastic
Old Aug 30, 2003
Jodster's Avatar
Post Whore General
tire calculator
Old Aug 30, 2003
Snort2001's Avatar
its in the menu bar on the left hand side. or u can just use Jodster's link
peimp
Aug 2, 2005 07:13 AM
vandejr93
May 8, 2004 10:07 PM
PeN8503
Nov 29, 2003 03:49 PM
FALKEN
May 30, 2003 10:35 PM
slowasscivic
Jul 29, 2002 12:42 AM
