Hotchkis anti-sway bars.
Old Aug 28, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
Anyone using them? I know the rear is 25mm, but what's the front? Like 27? Is there a way you can buy these seperately? I hate the fact they come in red. Think I'll powder coat them a different color if I get them.
Old Aug 28, 2003
civicvtec1ps's Avatar
Search and Learn
http://www.7thgencivic.com/modules.p...Suspension+FAQ
updated
Old Aug 28, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
hey were did u find them? how much?
Old Aug 28, 2003
All Eyes On Z
www.clubrsx.com.
Not necessarily cheap either. (Think I'll wait for the price to fall. I don't really need thicker bars more than I do stiffer springs.) There is a DIY on how to install it and their endlinks.
Old Aug 28, 2003
Zzyzx's Avatar
Autocross Junky
Are they adjustible?
Old Aug 28, 2003
RoadRunner's Avatar
so those will fit our civic's ??
Old Aug 28, 2003
All Eyes On Z
On clubrsx.com it mentions adjustablility but I don't see how. They look like normal bars to me.
And yeah, they'll fit our cars. (I can safely say that for the rear.) It uses the same anti sway bar design. The front resembles the EX bar. I believe DC5@EM2 owns these front and back? So yeah I can say they do work front and back.
Old Aug 28, 2003
All Eyes On Z
updated
I see... 25mm in the front. I went there earlier just to make sure I spelled Hotchkis correctly.
Aren't stock front bars 25mm?
Old Aug 28, 2003
robbclark1's Avatar
Retired suspension supermod.
25.4mm to be exact for the stock front. I guess they thought it would be matched if they were the same size. I personally don't think (going by predictions) that this would be the best set up. the 25mm bar might be too big for the front causing more oversteer. They are nonadjustable from what I know. There is also a "race" set of bars in progress by hotchkis.
Old Aug 29, 2003
All Eyes On Z
I thought it was the other way around?
Bigger in the rear causes more oversteer
Bigger in the front causes more understeer
*waits Zzyzx's wisdom*
Old Aug 29, 2003
Zzyzx's Avatar
Autocross Junky
Yup..... Higher roll resistance in the front= Understeer
Higher roll resistance in the rear = Oversteer
Figuring out how much roll resistane front and rear to make a well balanced car = Miracle
Old Aug 29, 2003
robbclark1's Avatar
Yeah I meant to say 25mm in the rear. My bad!! I botched it bad!! I am a bad mod, ZzyzX, you can give me a sock beating!!!
Old Aug 29, 2003
All Eyes On Z
So far I'll have to say I like the front stock bar but I truly won't know till I'm on spring rates I actually like.
Old Sep 2, 2003
Erichyung's Avatar
Erichyung is an unknown quantity at this point
how much are they?
Old Sep 2, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
WOW... 25 in the rear sounds like a hell of a lot. I've seen people pick up the inside rear with a 22 in the new Si. I don't know if I'd go for that stiff with out some really hard springs to keep stuff on the ground.
Old Sep 2, 2003
Zzyzx's Avatar
Autocross Junky
Picking up the rear tire on a FWD car is not that big of a deal, It mostly means that they need to stiffen up the front a bit.
Idealy, you want the inside rear tire to just bairly leave the surface when you are at the limits of traction.
Old Sep 2, 2003
bobbyd's Avatar
bobbyd is an unknown quantity at this point
They are adjustable by their end link I would imagine. I woupd rather go with Progress or Comptech and get the built in tie bar myself.
Old Sep 2, 2003
Zzyzx's Avatar
Autocross Junky
adjusting the end link does not adjust the strength of the bar.....
Heres an example of an adjustible bar Vs an non adjustible bar
See the difference?
Old Sep 7, 2003
cdmx's Avatar
Old thread i know, but arent these bars alot lighter also?
Old Sep 7, 2003
Zzyzx's Avatar
Autocross Junky
Not nessisairly. Most are heavier.
TheRiddicles
Sep 21, 2015 03:43 PM
CarbonFly
May 17, 2007 04:06 PM
Grey
Feb 6, 2005 10:16 PM
Civic2k1racer
Apr 30, 2003 02:12 PM
slikor
Jul 4, 2002 10:57 PM
