Tein Damper controller
Post Whore General
Sorry everyone, this is CantAffordRice again, too lazy to log out once more.
I'm just wondering if anyone knows where i can get the electronic controller (or whatever it is) for the Tein damper kit
Jodster and i are ordering the set together from Chuck at ShowStoppersUsa.
His for his EM2, mine for my Eg Hatch. (though it may be 2 months or so)
He doesn't want the controller, but hell, i think it sounds cool.
dammit, i was going to post and ask if i could get it for my tein ss. my friend was telling me about it and it sounded cool. cause crawling into my trunk to adjust my damper can be annoying and really hott.
Man, you guys are lazy!
EDFC will only work with the flex, but even then not even sure if it would fit under the hood. The trunk would be no prob, but it might not clear the hood.
EDFC will only work with the flex, but even then not even sure if it would fit under the hood. The trunk would be no prob, but it might not clear the hood. A member here has put a Flex set from a RSX on his civic coupe and used the controller. He had to notch two of the hood support braces on his stock hood to get the it to close. He also said that he did not think it would be a problem with an aftermarket hood. But, you could not even tell when the hood was closed that he had to cut it. By the way Tein does NOT recommend the application for our cars. It has been asked already. Hope I helped.
robjcivic
Mar 12, 2017 12:10 PM
RSKtakR
25
Sep 14, 2015 07:43 PM
Klame9420
Sep 7, 2015 10:03 PM
