tein ss or basic damper
Old Aug 22, 2003
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
what is the difference between the two, i know that the basic damper doesnt allow u to set the dampening, what does this mean? how much the springs compress? also how low does the basic damper go compared to the ss. does the ss handle sooo much better than the basic damper, thanks for all of your responses
Old Aug 22, 2003
VNlilMAN's Avatar
The Standard One
ya your right. basically only difference is the damper adjustment you have with the ss. basically you get to control the ride. if you want a more "luxury" feeling just put it on soft. if you want a "race/stiff" type suspension just make it stiffer. also the settings for the front vs rear makes a difference in handling. i have heard once you have damper adjustment you always need it...
the tein ss and basic i beleive uses the same springs so the drop is going to be the same(you can always order custom springs for them).
GolNat
Nov 27, 2018 03:32 PM
curaze
Sep 22, 2015 08:27 AM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
BBrosario
Sep 17, 2015 07:51 PM
