Help Please!
Old Aug 21, 2003
skrillionaire's Avatar
skrillionaire is an unknown quantity at this point
Question Help Please!
Hi. I just installed my skunk 2 coil overs and everytime i turn, there's a clicking sound. can anyone tell me what that is and why is it doing that? how can i fix it? thanks
Old Aug 22, 2003
VNlilMAN's Avatar
The Standard One
it might be the springs just settling in Or the springs hitting the top perch. 3rdcivic made a great diy on how to solve the problem. basically you want to seperate the spring from the top perch so that metal doesnt hit metal. he used some plastic/rubber type thing. try searching for "ground control noise solution" or something like that
Old Aug 22, 2003
dezod's Avatar
7thgen Power Maker
you top spring prech isn't aligned with the bottom, the clicking is the sliding of the top of the spring along the top perch.
Old Aug 22, 2003
Weaponx12o's Avatar
yea.. since the coilovers are smaller than the perch diameter, they tend to slide around. make an O-ring and place it between the sping and perch.
