Adjusting rear SPC camber kit
Old Aug 1, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
ok.. im looking for a tool list for the job.. other than the sockets used to remove, and install the camber kit, would i need an open ended wrench to adjust it? because i dont have any open ended wrenches... also do u adjust when the car is on the ground? or before the tire gets put on and lower?
i am asking this so i can get the wrench if needed...
also state what size...
Old Aug 1, 2003
robbclark1's Avatar
Retired suspension supermod.
you adjust while the tires are on the ground. I suggest getting it aligned. They will change the settings. Eye-balling it will only get you so far so don't keep those settings, but get it done professionally.
Old Aug 1, 2003
djmota's Avatar
yes you will need open end wrenches, not to adjust but to tighten down the lock nuts after the adjustment.
GolNat
Jan 12, 2021 09:06 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
JohnnyBxo
Nov 12, 2015 03:04 PM
chrisjackson321
Jul 12, 2015 03:00 PM
Jul 12, 2015 11:54 AM
