Slightly torn tie rod boot
Old Jul 18, 2003
Ty's Si's Avatar
Ty's Si is an unknown quantity at this point
Well I slightly tore the tie rod boot when doing one side of my suspension last weekend. So I packed it with grease and taped it up as a temporary fix.
I now hear creaking on the front driver side when I turn the steering wheel. I am assuming this is the cause. So a couple of questions:
1, What else might be causing the noise if it's not from the torn boot?
and
2, If it IS the boot, where can I get a new one and for how much?
Thanks.
Old Jul 18, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
Honda dealership. . .should be less than $30.
I bought one for that exact reason a few months back. Been so busy with getting the car ready for shows I've been too lazy to swap it out.
Now I get a horrid noise from that knuckle on the driver's side when I turn left.
Old Jul 18, 2003
BrotherSound's Avatar
BrotherSound is an unknown quantity at this point
I've heard the boots are a pain in the arss to install..
what did you use to remove your tie-rod end?.. I bought a tie-rod remover from pep-boys ($10) never once tore a boot, and each side has been removed twice already!
Old Jul 18, 2003
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
you shouldn't even have to touch the tie rod boot to remove it.. if you're going to install springs or coilovers, follow the DIY I made in the suspension forum / DIY area. it'll save you some money!
Old Jul 18, 2003
you could do that, but i never felt comfortable with hammering at my steering componenets. my opinion spend the $10 and get the right tool for the job.
Old Jul 18, 2003
Grey's Avatar
DIY King
I checked out a tie rod seperator from Autozone, but it's made for a tie rod that has a hollow bolt, or at least an indent for the little cone tip that mounts up next to it. I think Honda sells specialized tools for removeing things like this. I just did what Mex did though. Simply spray on some WD-40, make sure the wheels are straight, and hammer the ****er out from underneath. I used a two pound sledge. Worked like a charm. Thanks Mex.
Old Jul 18, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
I tore 1 side of my tie rod boot too, I just put some rubber washers in there and its been holding up fine, no noises or anything....
Old Jul 18, 2003
Ty's Si's Avatar
I did use a tie rod separator. Only problem is mine was so difficult to pry off, we partially ripped the very bottom of it while trying to pry the bolt out. It's just a little rough around the bottom, not torn up the side at all. So I packed it with grease and taped it up. That's why I think it may be a problem with the coilovers not being seated properly.
Will lubing up the springs on all 4 corners help solve the problem? The more I drive it, the more it seems to be a creaking from the spring and not the tie rod. But the noise is definitely from that same vicinity.
Give me some advice on lube...heh.
Old Jul 18, 2003
Derek-CEO's Avatar
Derek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz Erthang
hmmm...i get this noise on my front right. Sucks ***. I don't have the patience to do it my self. How much would something like this be to replace?
D
ricer_em2
May 11, 2016 08:09 PM
Wariogamer
Sep 29, 2015 09:49 AM
rovafa2002
Sep 28, 2015 06:57 PM
Bruce2
Sep 27, 2015 08:45 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
