Caliper Difficult to Move on Rear Disk Brakes
Old 07-09-2017
cpyz's Avatar
cpyz is an unknown quantity at this point
Hello Folks,
I changed my front brake pads today on my 2002 Civic SI without a hitch.
Was going to change the rear pads but the piston in the caliper was quite a bit more difficult to move than the front pistons were.
I'm curious if this is normal.
Is there a trick to moving the rear pistons (since there is also the e-brake mechanism)?
The wear on the pads were completely symmetrical and the e-brake definitely engages the caliper.
Thanks for the advice.
Old 07-09-2017
mikey1's Avatar
Re: Caliper Difficult to Move on Rear Disk Brakes
Originally Posted by cpyz
Hello Folks,
what do u mean by "move"
do you mean "remove"?
Old 07-09-2017
cpyz's Avatar
I mean, the old pads are thinner than the new pads, so I have to "move" (I mean compress) the piston so that I can put the caliper back on over the new pads.
It was fairly easy to push/compress the front pistons, but the rear one doesn't seem as easy...
it's not stuck though, since the e-brake seems to make the caliper pinch.
Old 07-09-2017
mikey1's Avatar
you should be compressing the piston back into the caliper BEFORE you remove the caliper....use a big c-clamp
now that you have it off....reinstall the old pad on the piston side and use a c-clamp on the pad and on the outside of the caliper to compress the piston
Old 07-09-2017
cpyz's Avatar
This is how I compressed the piston in the front...
it's just that the back is much more difficult. Does this indicate a problem, or is there a trick (given that the e-brake operates the rear piston as well)?
Old 07-09-2017
mikey1's Avatar
if thats the case, the caliper could be seized
Old 07-09-2017
cpyz's Avatar
I found a good source (minute 12):
It turns out you need to rotate the piston clock-wise and it will go in!
Old 07-09-2017
Rear pistons must screw in.
Make sure to clock the notches in the piston to the correct locations, they MUST clear the dowel pin sticking out of the back of the pad, so the piston seats flat against the back of the brake pad.
If you don't get this right, the piston will push on just the pin and the 'top' of the pad will wear at a bad angle.
Old 07-10-2017
cpyz's Avatar
Good advice...
thank you!
