17x7.5 45mm offset WILL IT FIT with 205 or 215???
Old May 29, 2003
ASIANPRIDE's Avatar
GODLIKE
ASIANPRIDE is an unknown quantity at this point
Exclamation 17x7.5 45mm offset WILL IT FIT with 205 or 215???
OK OK I DID A SEARCH.......but nothing was posted about a 45mm offset...
As I read...ppl with a 215/15 rubbed with a drop.....
A little background....I have GC's and Koni's and I plan to get a CAMBER KIT
Now...what tire fits the best I know that 205 and 215 both fit well...but I don't understand where the offset comes into play...
I am in a bind between the 40 and 45 size and I need to see about 205 or 215....
Once I fix my camber will it rub with my drop...ppl have been saying that 205/40 is to thin but I don't understand that...so is a 205/45 better (I think its to fat...I like the 40 profile) But where does the offset come into play in regards to rims size and tire size.....
I want 205/40/R17 or 215/40/R17...but which is the best for our cars with a drop and camber kit...???
Old May 29, 2003
Blown's Avatar
Blown is an unknown quantity at this point
How low of a drop do you have?
Old May 29, 2003
ASIANPRIDE's Avatar
GODLIKE
Umm....well we measured my fender to the ground at what 25 inches in the back and 23 in the front?? or something...Prob close to a 2 inch + drop...NOT 3inches...
Old May 29, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
i have the same spec, 17x7.5 with 45 offset, i went with 215/45/17 tires, my car dropped with h&r sports 1.3" lower before settle, just installed the camber kit 2 days ago havent bring in for alignment yet but i corrected the rear camber on one side only and it LOOKS like 0 degree camber and no problem with rub, and i suggest getting 215 tires cuz u have 7.5 wide rims so that your rims are better protected, i dont even know if 205 tires will fit, but i suggest get a 7" wide rims i already bent mine a little going through a HUGE pothole on highway after 10 MINS OF DRIVING after i install the rims 2 weeks ago, hope this help
Old May 29, 2003
but if u have a 2" drop i suggest u get 215/40/17 tires so that rear fender wont rub but rims are less protected if u have a 40 series tires
Old May 29, 2003
or u can roll the rear fender so no problem at all after the camber kit or just dont adjust the camber so it wont rub at all but tires gonna go fast
Old May 29, 2003
ASIANPRIDE's Avatar
GODLIKE
Yeah....I know they are less protected...and that sux the big one....cuz it is taking me forever to get my rims in...and the roads in Edmonton are ****...but I know lots of ppl with 40 and it seems to be working well so far.....Except for one guy who mashed his rim...but he mashes his car all the time......
So if the offset is how far the rim sticks out....then....you don't think a 215 will be to big....??? But I understand the idea of putting a 215 on to protect it better.....I am mostly conserned about the Rubbing..but if you guys don't rub with a 45 profile..then a 40 should be fine???
Cuz I don't like the look of 45...it's to fat for me.....
Old May 29, 2003
ASIANPRIDE's Avatar
GODLIKE
I don't want to roll my fender......and I will get a camber kit...I will prob go with 40 profile....
I'm just unsure about a 215 with a 45 mm offset.....
Old May 29, 2003
Blown's Avatar
And 7.5" width rim...
Old May 29, 2003
for me its fine with 215/45, but my car not as low as yours, 215/40 will be fine, i just had bad luck that i went through that BIGGEST pothole on the whole highway!!!!!!u can always adjust the camber to the degree that it wont rub the fender, na, its perfect with 45mm and 215 tires imo
Old May 29, 2003
yeah, 215 is the thickest u can go without rubbing in the front while doing full turning cycle, and 205 is too thin for 17x7.5 rims
Old May 29, 2003
ASIANPRIDE's Avatar
GODLIKE
OK THANX GUYS.....
I will be getting 215/40/R17....Now which rubber to get...haha...we've (Blown and I) been looking for almost a week now..doing research.....
Narrowed it down to.....Yoko AVID H4....maybe the EVS 100..... Falken Ziex ZE-512 and the Nitto Neo Gen (we can't get it in Canada)....any suggestions on tires that last the really long....cuz...
Yoko Avid H4 UTQG: 360-A-A
EVS 100 UTQG: 280-AA-A
Ziex ZE-512 UTQG: 420-A-A
Neo Gen UTQG: 280AA
Old May 29, 2003
depends how much u wanna spend, do u go to track, normal driving but agressive on corners and dont go to track? i dont go autoX or track but i do corner aggressive all the time and i got the es100 and its very good on dry and wet (and do fast corners while road is wet), plus the thread looks good!!, but i dunno about nitto and falken tires, kuhmo 712 are also good, not as good as es100 but it save u 200-300cad than the es100, but if u planning on using the tires for winter get h4, my friends have h4 on and she said its pretty good both dry and wet and thread last alot longer than es100
Old May 29, 2003
ASIANPRIDE's Avatar
GODLIKE
I got winter tires....I don't plan on going to the track..and I love to drive aggressive...that is why I want something that wont get warn down super fast......So how much did you end up paying for yours???
Old May 29, 2003
i paid 870 installed and balanced for the es100
Old May 29, 2003
ASIANPRIDE's Avatar
GODLIKE
Koo...thanx....now it's just up to me to chose...ugh....all in all..they will all stick...
Old May 29, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
45 offset on a 7.5" rim and a 215/45 tire will stand the possiblity to rub the front liners when you turn fully. There are some people on here who have +45 on a 7.5" rim, but I don't think they're running 215/45. I don't know that you need to worry about rubbing the fender lips too much with that much offset, but it depends how far you drop.
BTW... cheapest place to get AVS ES100s is Tire Rack... $97 each.
Old May 29, 2003
ASIANPRIDE's Avatar
GODLIKE
Koo...I'll look into it...
Old May 29, 2003
go on tirerack.com and check for reviews on tires, if u want something that stick to the ground and yet not too much money i suggest kuhmo, its also 280AA, should be aroun 650 installed if u find good deals in alberta
Old May 29, 2003
ASIANPRIDE's Avatar
GODLIKE
Ziex ZE-512
All Season
High Performance
UTQG: 420-A-A
Overall Customer Rating
4.5
We are getting these....
Old May 29, 2003
ASIANPRIDE's Avatar
GODLIKE
Falkens....!!!!
Old May 31, 2003
Nitek's Avatar
Nitek is an unknown quantity at this point
I have 215/40/17 with no wheel gap or a camber kit. I its a 7.5 rim on a 45 offset. This is the biggest offset you can use, or youll rub the rear rim on the lower control arm. There is only a couple of millimeters of clearance! Camber needs to be fixed, but to do so, youll have to roll the fenders to have zero camber. The only problem i had of this set up, is the tire not fully seated on the rim, which the lip of it is actually bulging out of the tire by a couple millimeters. This looks like *** and ruins the rim quickly (anybody else have this probem)? I love the low profile look of it but the rim doesnt fit properly. I also have heard that the 7.5 in rim will fit perfect with 215/45/17 because of more sidewall to stretch on the rim.
Old Jun 1, 2003
HondaLuver's Avatar
Its a celebration bitches!
SO3's or F1's are the best but pricy... o welll
Old Jun 1, 2003
Blown's Avatar
I don't understand this. I researched the tires and they are meant for 7-8" wide rims with 7.5" being the best fit. Maybe the guys installing your tires werent doing it correctly? I already had 215/40/17 on my old civic and the rims/tires fit perfectly.
Old Jun 2, 2003
ASIANPRIDE's Avatar
GODLIKE
Ok so then what is the problem...is it the 7.5 that gave you the problem? Because I don't want to get the 215 if it wont fit right....
And I don't plan on slamming my car that low so I have no clearance...But I do need a camber kit
Old Jun 7, 2003
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
lol, it wasnt me who mashed the car last time. haha. the avalanche guy. haha. but my rims are mashed. oh well. car is evidently sold anyhow.
GolNat
Nov 27, 2018 03:32 PM
rnaodm
Sep 21, 2015 12:42 PM
Dave Brabant
Sep 12, 2015 08:39 PM
JohnDay
Wheels and Tires
Sep 6, 2015 06:42 PM
